Can I Clear This by Myself?
   / Can I Clear This by Myself? #11
I agree with Kthompson, check with local loggers, you make some $$$. Also ask around about those in need of fire wood.
An experienced operator can easily take a whole tree{roots and all} down much easier then it is to just dig up an old stump. As Kthompson said, roots will need a lot of fill when done. Plus you'll have to find a place to get rid of the roots, they won't burn until dry and that can take some time.
It takes a whole crew of equipment and people to clear this much in a short tme. Logging will leave stumps, tops and the undesireable trees behind. The equipment you have will work just fine, don't get impatient and plan to cut small tracts out at a time (acre per weekend?). Uprooting the whole tree is easiest, then cut if you want. Rough grade as you go, filling the stump holes. Spend a couple minutes picking most of the dirt off the stump. Sliding trees is easier than lifting to move. It shouldn't be a problem to burn in your part of the state, check with the county for a permit and for burn season times (now is open). Pile your burn up as high as you can reach, it'll look daunting the first time but you will be ok.
Pulp wood is still at $10/ton, we load their trailer, they haul. Firewood processing co. might work ok if you can locate one near you. Firewood unless for you or family, I would pass. People are funny, they say one thing and do another. They really want free firewood only if you cut, split, deliver and stack for free. If an individual injures themselves on your property, you are liable for them and their injuries even if they sign a waiver of liability. One lawsuit will change your mind quickly.
Yes, the whole process will take time,. The more of it you do, the more efficient you should become. Most of us have more time than money, we just don't think we have the time.
   / Can I Clear This by Myself? #12
I've been to Frostburg! We were picking up fire tankers in Meyersdale.
We had some clearing we did. I have a 21 HP Kubota B21 TLB. I hired a local guy with a track loader w/ 4-way bucket to come in and push down the trees, then haul them into areas/piles roots and all. Then I limbed them, some guy bought the timber, I burned what was left of the limbs after the local wood stove crowd got what they wanted. Then the track loader guy came back and buried the stumps.
I used the B21 to help hold trees while I was limbing, clean up the ground, pile the limbs, stack the timber, and dig up any root pieces that didn't come up with the tree push over.
You could do the same approach and the tasks you are undertaking would be matched to your equipment. If you took 5 acre bites of the problem, it would be manageable and if this approach didn't work for you, you wouldn't have 30 acres of pushed over trees to contend with.
Pete
   / Can I Clear This by Myself? #13
A one or 2 man operation can clear out a heavily forested 5 acre lot in about 1 week. A skidder can move a lot of material fast and have it stacked in a clearing, Log truck/s come and take it away. I suggested trying to have a logging outfit because it may help with $$$, plus you won't just be wasting lumber. A good skidder operator{respectable logger} will even push up the brush piles so you can burn them. Probably take a month or less, depending on weather job demand etc, for them to be done. In our neck of the woods the loggers don't just take "lumber wood" they also sell firewood in log length{the owners still gets a cut of this}. Not to mention if you explain what you're doing they may even help with stump removal. From what I can see stumps are going to be your biggest issue. Not only do you need to get them out but you need to get rid of them, dump truck sure would be handy?
Tlbuser, you may be correct about lazy incompetent firewood getters. At the same time there are those that respect and take responsibility for their actions. Seems like there could be some sort of signed agreement if one were to choose this route, especailly if the owner were giving the wood away????
   / Can I Clear This by Myself? #14
Pete
I agree, I've seen folks go in and cut cut cut then go numb because they can't handle the clean up. It's much easier{for the DIYer} if one takes small bites and cleans as they go.
   / Can I Clear This by Myself? #15
Lazy was just part of it. One of our sites we let people in to cut firewood. Had them sign a waiver of liability drawn up by our attorney. Guy cuts himself with his chainsaw, we got sued, he won in court. That particular scenario won't happen to us again.
   / Can I Clear This by Myself? #16
Tlbuser; that sad, these sue happy people can really ruin it for the rest.
   / Can I Clear This by Myself? #17
That is sad! They SIGNED a waiver and STILL won for thier OWN carelessness??!!
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Deere 331G (A50123)
Deere 331G (A50123)
1 pallet of Brake Chambers (A53117)
1 pallet of Brake...
2023 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2023 PETERBILT 389...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
