1000 rpm pump run on 540 rpm
/ 1000 rpm pump run on 540 rpm #1
desert trader
Member
Shoshone,Idaho
Massey Ferguson 165
Can a 1000 rpm pto pump that puts out 23 gpm 2200 psi be run on a 540 rpm tractor and if so what would it do to the gpm and the pressure out put.
/ 1000 rpm pump run on 540 rpm #2
Output pressure is determined by relief valve setting and applied load. Pressure will not be affected by operating a sound pump at approximately half speed. Flow from fixed displacement pumps is speed dependent. GPM will be approximately 12.25.
/ 1000 rpm pump run on 540 rpm #3
Yup, as Rick wrote...pressure is constant, GPM will be affected.
Hey thanks alot for the info you just might have saved me a lot of money.
It's great to have a place to get must needed info,thanks again.
/ 1000 rpm pump run on 540 rpm #5
As said above... You will however need to keep the rpms up for good pump performance. 1/2 speed is barely a problem, but idling down on the already reduced pump speed will have it running at 1/3 or 1/4 speed. As the oil thins with warming, internal pump leakage [proportional to output pressure, but independent of rpm - and increasing as the pump wears] will start to overtake output. For example ... In a fully warmed system running at full pressure at 1/4 pump nominal speed it is likely you will only get 1/8 of nominal full rated rpm flow. Maybe less. At 1/2 pump speed youre pretty good - instead of the 50% capacity you will get around 40% at pressure. Not too bad.
Also, some types of pump are better than others for reduced speed service because they have less internal leakage. I have assumed it is a gear pump.
larry
/ 1000 rpm pump run on 540 rpm #7
Is this a pump you have, or thinking about getting. That pump requires about 34 HP to run it at a 1000 rpm.
I should be okay I have MF 165,I'll just have to get a pto shaft adapter.
/ 1000 rpm pump run on 540 rpm #9
Hes running it at 540/600. Less than 20HP.
larry
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
45" PALLET FORKS (A60430)
45" PALLET FORKS...
3015 (A56857)
3015 (A56857)
205196 (A52706)
205196 (A52706)
2025 HD Trailer Solutions EQ17.5 20ft. 8 Ton T/A Equipment Trailer (A59230)
2025 HD Trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
