Cat_Driver
Elite Member
- Joined
- Jan 15, 2008
- Messages
- 2,517
- Location
- Coachella Ca.
- Tractor
- 2016 Kubota 4060, 2017 Tackeuchi excavator TB260
The "reward" is for proof of PARANORMAL activity and dowsing is not paranormal.
I'd take two thin wires -- straightened coat hangers, usually -- and bend them at a 90 degree angle near one end. I'd put the short end in each hand, make a loose fist, and bring the fists together. The long ends of the wires would be pointing out, parallel to the ground. He would hold them loosely enough so that they could move freely.
there is a reasonably logical explanation for dowsing which doesn't invoke any supernatural explanation. A radio engineer in the UK experimented on himself, using the famous wire coat hangars, to test his theory that water radiates, and that the human body can respond. This response causes the muscles in the arms to contract in such a way that outstretched wrists will turn imperceptibly inwards. The natural consequence is that gravity will cause the two wires to dip downwards, and thus cross. This much is easily tested with just wires - no need for water - turn the wrists inward and the wires dip and cross.
He covered his torso with an aluminium "cloak" to shield the supposed radiation, and cut apertures in it to try to identify just where the body reacts, and found a two inch diameter area in the back which appeared to be sensitive.
Next he used his radio engineering knowledge to build a transmitter
in the range of freqencies he thought must be applicable. This device was demonstrated in a BBC television program: the transmitter was planted on one side of the River Thames near London, and from the other side he was able to row directly towards it. He said he just had to keep the boat heading in such a way that he could feel a sensation in his back.
A series of subsequent tests suggested that about one in three of us has this capacity to dowse, and it's not unreasonable to suppose that it was universal at some time in our past, but has largely atrophied from disuse. Finding water in the wild may be a matter of life or death.
Being curious, I tried the wires for myself - it worked remarkably well and, as it happens, allowed me to find a main water cock buried under years of vegetation in a ditch near our country cottage. I walked along one side of the lane and chalked a mark where the wires crossed. I repeated this on the other side of the lane and marked again - this mark was about three yards further on. Stretching string through the two marks and extrapolating into the ditch, located the water cock within inches. Builders had been searching for several days.
