emergency use of kerosene
   / emergency use of kerosene #1
nybirdman
Super Member
north of upstate ny
Kubota L4240 HSTC,L3000DT
I have kerosene in bulk(home heating)..I normaly buy fuel for the tractor at the pump,but in an emergency situation can I use straight kerosene with-out harming my 2008 tractor?Second question;what is a simple fuel transfer system ,short of a sifon.....drill motor with a small pump?I use about 150 gallons a year of diesel..I don't want to put in tank just for diesel.
   / emergency use of kerosene #2
You can use kerosene in winter when you still have diesel in tank. You will have little less power, thats about it. Using kerosene in summertime is not a good idea, it will burn much hotter and thats not good for diesel engine. During the winter, since its cold out and it helps to ungel diesel with kerosene, its not much of a problem. You will have some naysayers who say don't use kerosene, but people do it all the time.
I used it once, I forgot to add additives and it was too late to go to store so I added kero to my diesel fuel when I needed to plow that night when it was -5. I am not sure if it gelled or not but I wasn't taking chances, I had no spare fuel filters and still on the originals.
   / emergency use of kerosene #3
We've been working on a military tender, cant disclose details but it involves Deere engines. The army has the same problem as you: They want to use kerosene when nothing else is available. Deere prescribes additives because the common rail system will fail because kerosene doesnt lube the mechanicals enough.
Some engines will run fine on it with just a little engine oil added to the fuel, but others will get expensive damages. In Europe, some freaks are running their Diesel cars on used frying oil. The ones with the French CAV pumps have trouble, the Bosch VE pump takes it better. Common rail systems dont like it either.
Inline pumps dont seem to care at all. But just be careful with common rail !
   / emergency use of kerosene #4
I've done it before but only back in teh days when it was cheap. Kero down here is over 6 bucks a gallon right now. Not buying any of that.
When I was in the service we ran all of our portable gasoline engines on JP5 or kerosene. We had little propane cylinders rigged to them for starting aids and once they got started everything was fine. We never added anything to the fuel at all.
   / emergency use of kerosene #5
$6/Gallon? WOW, that must hurt the wallet. We just filled a 5 gallon kero can at $2.99/Gallon yesterday.
Aaron Z
   / emergency use of kerosene #6
I second the concern about the lubricity, or lack there-of with kero. Mixing w/ diesel is no problem, dont all the time to make up winter blends but straight kero I'd feel better with an additive for lubrication. (The old fuel blends had more sulfur which was what provided the lubricity, now with low sulfur fuels even stright diesel has less lubrication but many of the additives are designed to make up for that)
   / emergency use of kerosene #7
my wife had a kerosene heater for the greenhouse when we were dating, and would pick up 5 gallon pails for 6 bucks, it later went to 48 bucks. I still have a couple of the cans that have price stickers that range from 6 to 20 dollars.
Times change, and now we have a diesel drip stove, kerosene is just to expensive
   / emergency use of kerosene #8
OP, Are you sure it is kerosene in the home heating tank and not #1?
   / emergency use of kerosene #9
When Ultra Low Sulfur Diesel first came out several people reported pump damage. If I was going to run the kerosene I would put about 4 ounces of Power Service or some other diesel fuel additive and 6 ounces of Marvel Mystery Oil per five gallons of kerosene. That should protect the pump. I would also monitor the temperature gauge closely to insure the unit was not running hot. Kerosene has a Flash Point of 38 72 C which according to the information I have been able to find indicates it is combustible as well as flammable. In my opinion kerosene because it has a high flash point could pre ignite and piston damage could occur.
Information obtained from WEB:
There are various international standards for defining each, but most agree that liquids with a flash point less than 43ーC are flammable, and those above this temperature are combustible.
Every flammable liquid has a vapour pressure, which is a function of that liquid's temperature. As the temperature increases, the vapour pressure increases. As the vapour pressure increases, the concentration of evaporated flammable liquid in the air increases. Hence, temperature determines the concentration of evaporated flammable liquid in the air.
Each flammable liquid requires a different concentration of its vapour in air to sustain combustion. The flash point of a flammable liquid is the lowest temperature at which there will be enough flammable vapour to ignite when an ignition source is applied
Examples of flash points
Fuel Flash point Autoignition
temperature
Ethanol
12.8 ーC (55 ーF) 365 ーC (689 ーF)
Gasoline (petrol)
<−40 ーC (−40 ーF) 246 ーC (475 ーF)
Diesel
>62 ーC (143 ーF) 210 ーC (410 ーF)
Jet fuel
>60 ーC (140 ーF) 210 ーC (410 ーF)
Kerosene (paraffin oil)
>38?2 ーC (100?62 ーF) 220 ーC (428 ーF)
Vegetable oil (canola)
327 ーC (620 ーF)[1]
Biodiesel
>130 ーC (266 ーF)
Gasoline (petrol) is designed for use in an engine which is driven by a spark. The fuel should be premixed with air within its flammable limits and heated above its flash point, then ignited by the spark plug. The fuel should not preignite in the hot engine. Therefore, gasoline is required to have a low flash point and a high autoignition temperature.
Diesel is designed for use in a high-compression engine. Air is compressed until it has been heated above the autoignition temperature of diesel; then the fuel is injected as a high-pressure spray, keeping the fuel-air mix within the flammable limits of diesel. There is no ignition source. Therefore, diesel is required to have a high flash point and a low autoignition temperature.
Diesel flash points vary between 52 and 96 ーC (126 ーF to 204 ーF). Jet fuels also vary greatly. Both Jet A and jet A-1 have flash points between 38 and 66 ーC (100 ーF to 150 ーF), close to that of off the shelf kerosene. However, both Jet B and FP-4 have flash points between -23 and -1 ーC (-10 ーF to +30 ーF ).
   / emergency use of kerosene #10
1*I have kerosene in* bulk(home heating).
2*I normaly buy fuel for the tractor at the pump,but in an emergency situation can I use straight kerosene with-out harming my 2008 tractor?
3*Second question;what is a simple fuel transfer system ,short of a sifon.....drill motor with a small pump?4*I use about 150 gallons a year of diesel..
5*I don't want to put in tank just for diesel.
1*This don't sound right.*How big is your tank?
Most home furnaces are set up to use HHO which is the same as Diesel.
2*I would not run the tractor on straight Kero. because it doesen't have enough lubricant in it.
3*I would fill the tank with the proper fuel off road /HHO.
Then I would just add a pump to the the tank and fill my tractor with that .
4*150 gallon a year would be well worth a tank and an elect pump set up but you might be able to use the tank you have provied you fill it with the right fuel .
5*Then put the right fuel in the tank so you can add a 12 volt pump .
This way you can use the same tank for the tractor and the house.
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2025 GPS Utility Trailer, 11.5 foot (A56859)
2025 GPS Utility...
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
Doosan D355-5 Forklift (A55973)
Doosan D355-5...
