Converting a house to a barn???
   / Converting a house to a barn??? #1
clovergamecock
Gold Member
Clover SC
Kubota L2800 4WD FEL
I purchased a peice of property a couple years ago that has a 2200 sqft single level brick home on it. The home structurally is sound but it is in need of more repair than I am willing or want to do. I have it listed for $10000 and the buyer moves it but if it does not sell I am wondering can I make it into a barn somehow?
Can the bricks be removed and the walls and floors brought down just leaving a standing roof structure That I can make into stalls and tac room and hey storage?
Thanks
Wade
   / Converting a house to a barn??? #2
Depends on how it is constructed post some pics inside and out for starters some you will be able to glance at and say whether or not.
This house has a new roof on it so if I can keep the roof standing and remove everything around it it would be awesome. I would als like to salvage the den as a tac room because of the beautiful fireplace. Thanks for any and all input!!
Wade
   / Converting a house to a barn??? #5
I would be assuming that the house was built on a foundation? most likely a Block foundation elevated enough to provide a crawl space? if this is the case then the house walls are built on top of the floor system and would be very difficult to try and remove the entire floor from underneath the walls and load weight of the roof, first off you would need to remove all the brick as they are tied into the walls every 6 or 8 corses,....... Now you could if you thought and plan this out, cut the floor back to within 1 foot of the foundation keeping all the cuts the same and equal to each joist and then install a Ceil to the ends of the joist tying them all back together, in other words leaving a 12" perimeter of floor around the entire interior of the structure, you would of course have to leave and design the stalls around the interior weight loaded walls, this wall would be in the middle of the house running the length of the house and usually is will be a one side or the other of the Hall wall, this weight load is also supported by piers and a beam from underneath the floor,
But you did mention lowering the roof.. is the house under one roof system? meaning is the roof the same all the way across both front and rear of the house? have you looked up in the attic if it is trusses? or stick built rafters?
if being trusses you have another option to lower the roof, Although would require large heavy duty crane,.... need to start out knowing how the house was built? ;)
   / Converting a house to a barn??? #6
I see you post up some pictures while i was replying with my well known Long replies:D
it does look like all the roof will be built on just 1 level of wall plate, I think I see 1 short step down? although would still be attached at the same wall level, My guess is this was a Carport and was closed in,
the Gable roof some call "Dog house" or "Dormer roof" can be removed easy enough and sheath on across and lace in some shingles, But really nothing wrong with leaving it in place, would save you from having to roof over it,
Now to find out if they're roof trusses up there?
   / Converting a house to a barn??? #7
What kind of repairs does it need that you don't want to repair it to use as a house?
It seems like a lot of work to "deconstruct" this house to get a shed type building.
How did you set your $10K price? Around here, I would have talked to one of the guys who moves houses out of the way of road projects and then resells them to get a price.
It needs a heating and AC system. All new carpet. It has mold in the walls where the roof was leaking in about 20 different spots. It would take way more to fix it up than what I want to put in it. It is also sounding like there is a lot more to converting it to a barn than I care to do.
We did put a new roof on it which ran about 4500. It has 3 year old storm windows. It has already cost me 5000 in taxes to just sit. Adding all this up is where I arrived at the $10000 price. I am definately negotiable if you know anyone in the south carolina area. ;-)
   / Converting a house to a barn??? #9
I am not a house mover, but I think that the brick walls, and the brick fireplace make this a poor candidate for moving.
If you can get $10k that is great.
Depending on zoning, turning it into in-law quarters may be a financially appealing option.
   / Converting a house to a barn??? #10
Brick veneer houses are raised and moved all the time. There is one on a trailer near me. It has sat there on the trailer for a number of years.
The fireplace might pose a challenge.
If you keep the house and remove the walls, you will need to address structural stability.
Lateral loads are currently resolved thru the walls.
I would leave the brick veneer in-place if at all possible.
Good Luck.
Yooper Dave
   / Converting a house to a barn??? #11
That's an interesting question you have.
If the house would be usable as a hay shed and stalls without raising the ceiling height, you could keep the corners intact, say 8' of wall on each side of a corner, then replace wall sections by building headers across new openings. The height of the openings would be about the same as for a standard 6'-8" door way. The width of the new openings could be whatever you need up to 10'-12' without risking too much structurally.
It seems like you would have to either cut down the foundation or raise the roof to make it very practical. If you cut down the foundation (assuming a crawlspace) at new wall openings, you would need to bring the outside grade level down also at those points. And make the drainage work. Raising the roof/ceiling height just doesn't seem practical from a cost/effort standpoint.
All in all, it would be more work to make a shed out of it than to fix it up as a house I think. It looks too nice to just tear down, but if you went that way, you could leave the fireplace standing and build a new barn with tack room around it. You may have to add some height to the chimney depending on the new shed design.
Good luck.
Dave.
   / Converting a house to a barn??? #12
Thanks
Wade
It doesn't look to be in bad shape, If I may ask, why don't you rehab it and rent it out?
In looking at the pics, most of the repairs would be cosmetic, and probably not all that hard to do, or if you don't want to do it yourself, hire out.
In todays economy, to have a cash flow out of a rental is a
real plus. There are a number of loan programs that address remodeling/rehabbing if you don't have the funds available.
   / Converting a house to a barn??? #13
I know the answer to this, :rolleyes: it will be very costly to rip out the drywall down to bare studs in order to remove Mold spores, you will have to use special companies in the Field of removing and desposing of the contaminated materials and who knows what else is lurking inside the walls, could even Lead to termite infestation,:confused: I've seen this more then a few times, and actually started into rehab jobs only to find that the houses will have to be condemned and torn down, Yes if you spend enough $$$ you can bring the house back to code but is it worth it, Nope! I can give you 3 people to talk to that thought they could afford to clean it up and restore their houses, but wound up folding about half way through simply because every little thing had to be inspected and approved by environmental inspectors, and there just no satisfying those folks short of demoing the house, Plus the liabilty of renting a house with these kind of issue can be a hole other can of worms... if you think the house has reached this stage then count on having it taken down and deposed of in green plastic bags,
Sorry!
   / Converting a house to a barn??? #14
i think your best option would be to sell every peice of cabnatry, trim, and doors that you can plumbing lighting fixtures to, if its ten years old then all that stuff is not made any more nd people will be looking for it some were. after that you prolly have to eat the cost of the roof job you had done.
you could then dismantel the whole thing and re use the foundation in some way to build a real barn.
as to rasing the roof you realisticly need a pro to do that safely, and to acomplish open sides you would need some pretty serious headers, that being said it would prolly be cheaper than a stick built barn due to roof being finished.
a metal building or pole building will be cheaper due to different more eficent matireal use so dont cmpare prices directly
   / Converting a house to a barn??? #15
That house is way too nice to move or convert to a barn. It would be cheaper to build a barn than convert it. You don't have to rip out all of the drywall. Just the areas that are moldy. Some of those may even clean up. Clean it up, fix it up, and rent it. Around here that house (rehabbed) would easily rent for $1500 or more a month. After taxes a couple years of rental income would cover the rehab costs. After that its just a money maker.
That house can be moved, bricks, fireplace and all. It's probably not cost effective to do so. In my area when a house is moved it has to be brought up to current building codes.
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
