Float on BX
   / Float on BX #21
OK - back to float....:)
BX23
I too had a problem this week while clearing snow - I had read of this and tried it a few times with no success - but it sounded very useful. Being new to this, I only tried about the same 'push' that had activated curl and lift - just tried for more shaft distance or a space for it to fit into - like an old manual shifter.
Is there a trick, or just how much extra force (2x,3x), any kind of detent to the shaft (up, down, twist)? How would one confirm a failure rather an operator problem?
THX
Not every Kubota has float perhaps, but the manual that came with my loader says directly that mine does have float.
I don't think there is a trick about it, but I do have to press harder to get it into float.
The detent balls that hold it in float will also offer resistance to keep you from going into float by accident. I have to push through the resistance of the detent balls, so perhaps one does have to press a bit harder, perhaps twice as hard?
The joystick in the video works opposite of my joystick, so to make sure there is no confusion, I think this would be correct in all cases, all loaders:
You push the joystick in the same direction that would make the bucket go down toward the ground. Push about twice as hard as normal down, and a bit faster (for a bit of momentum), and that should probably engage all but the most sticky floats. If that does not work, look at the manual that came with the loader (if you have the manual) and try to verify that your loader has a float position.
I would say a failure vs operator error would be that your manual says you have a float position, and you have done what I said above, and you tried once more pressing even harder, but were afraid you might break something, so you dicided that the valve is malfunctioning.
   / Float on BX
My BX goes into float fairly easy, about like the feeling of shifting gears on a manual transmission on a car, it just kind of notches in there. It is very handy for snow removal. I use it a lot when back dragging snow away from my garage doors as well as when going forward.
   / Float on BX #24
Well - based on other's experiences....
I went on out to the garage and tried it on a non-running tractor. (I won't start it in the garage - didn't take long to learn that!) Anyway, it didn't want to move past the 7 of 8 compass rose points. I gave it a good shove up towards 12:00 and it went, and stayed! - once. Now, it goes there - extreme 12:00 - and kinda' hangs a bit - but doesn't stay - it falls right back to regular 12:00 (it does bump past something on the way). Hope I didn't break anything expensive!
This is on a stopped engine. I'm hoping a spool or something gets set or reset when the hydraulic pressure is back up.
We missed last night's predicted snow - hoping for the weekend!
   / Float on BX #26
Do you push it out first? pull it out with another tractor? garage floor sloped towards the door? How does this work?
   / Float on BX #27
I leave a strap under the loader and over the 'bumper' hook, and pull it out with the truck. (It lifts the bucket a bit and doesn't scratch the concrete.) I can push it, but that strap over the 2 in ball on the Dodge is real easy and quick. If I start it inside, I get that visible start smoke and then smell it for 2 days. If I just back it in, fast, it blows right out.
Any thoughts on whether I broke it, or is it a part that regains movement over time?
   / Float on BX #28
Any thoughts on whether I broke it, or ir is it a part that regains movement over time?
I doubt you broke anything. Mine is not that great at staying in the float position, and I can work with it just fine, thanks to power steering.
   / Float on BX #29
I was smoothing my slag drive with My bx1500.
Lowered the front blade to back drag and got hung up with 2 much slag behind and in front of the blade.
Went to rise the blade and it wouldnt budge .
Needless to say I was stuck .
Next morning it hit me try the float and it worked allowing me to back the tractor up the drive way .
but i still couldn't get the blade to lift off the ground so i still had a problem .
Later discovered the 3 point was engaged was the reason the fromt blade would not raise up. Duh!
   / Float on BX #30
That is how my 2360 is also,it goes into float easly and will stay there.
Mitsubishi 24V Electric Pallet Jack (A51691)
Mitsubishi 24V...
JOY G185XS PORTABLE AIR COMPRESSOR (A51248)
JOY G185XS...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
