carpolisher
Member
- Joined
- Jan 17, 2010
- Messages
- 36
Hey all,
I was that guy a few months back who posted about asking questions then disappeared. Not sure how but every time I visited the page for the next week or so it never updated so I figured the thread died. If I may still ask questions, I certainly do have a few. (Some basic background, I plan on using a two 28'x28' modules, sheltered on 1.5 sides and the roof. Not looking to build for 2-3 years, but want to do as much work as I can myself)
-I do still plan on using Terra-Dome. How has your experience been with them to date now that you've had some time to really look at their work? Would you recommend them?
-Waterproofing: What have you guys learned about it so far. I read the 10 or so pages after the web error and see there has been some problems. I've been doing my own research, but have no idea what to use. Everything sounds good, but there is just so little posted about actual experience with product/technique X. What would be your ideal drainage/waterproofing system if you did it all over again?
-HVAC: I really want Hyrdonic Floor heating (radiant floor) especially since there will be such a large concrete mass, but am having a hard time justifying the extra cost since a forced air ventilation system is almost required for safety and dehumidification. What convinced you to do in-floor heating? (By the way, I have been using http://zurn.com/images/pdf/ZPM02101.pdf as my reference for designing the hyrdonic system.)
- How are you finishing the interior? I plan on using metal studs for interior walls (low/zero smoke in the event of fire and no worries of mold damage), but are you using drywall or plastering the walls? Using products from Dietrich, I am just thinking about using plaster (also no worries of mold damage) for all the interior walls.
-What is the cost of insulating, waterproofing, and draining? They don't really mention it which scares me. I have been trying to get a cost estimate going, but if they don't include it, I worry it has to be a significant cost addition if they don't mention it.
-How good were the concrete forms? Did you lose any receptacles/box cutouts due to sloppy side wall forms allowing concrete to pour into them? This was a concern I read on another source I found. Do I need to plan on losing some so add extra?
-What solar tubes are you planning on using? I found a company that offers a really nice product, Solatube. Are these what your using, and if so, have you had any experience with them? I plan on using these in the bathroom because They can have a built in light, 110 cfm fan, and a dimmer for the natural solar light. Probably expensive as sin, but meets my bathroom requirements.
-Did Terra-Dome provide any HVAC analysis with their design? It says they provide a HVAC plan, so I'm guessing they must have sized an Air system.
-Where is the HVAC plenum located? Is it located in the concrete slab, or below the slab? (aka.. will it interfere with Hydronic in-floor heat or conduit/cable?) I got the impression it's located under the slab, but wanted to confirm that.
-What are frost footings and where might they be needed? I am guessing they would be required on the exposed walls, and normal footings on the earth sheltered walls, but haven't been able to get a clear answer from Terra-Dome on this when I asked.
Well I think that's about it for my off-hand questions. I have been having a lot of fun designing this house in AutoCAD. I have the layout done, now I'm just preparing the different plans now (electrical, plumbing, Hydronic Heating, etc.) Seeing all your projects really makes me excited to move forward soon with mine own. They all look amazing and I've learned a bit from reading all these posts!
Allow me to introduce myself. My name is Bob, I am a retired facilities engineer from New Holland. I plan on having Terra Dome construct 3.5 modules this spring in central PA. This was the result of several years studying the subject and reading others experiences shared in wonderful sites like these. My recommendation is research as much as you can on earth sheltered technology. One of my favorites is John Hait's book Passive Annual Heat Storage, Improving the Design of Earth Shelters. There is a lot of good information on the subject of waterproofing, insulation and ventilation. I look forward to sharing information and experiences with you all on this site. Thanks.......
