Hi Steve,
Sounds like progress is being made. Were you thinking of using solar hot water for the hydronic heat? I have thought about that for our house. My problem, and you may be different, is if the sun is shining, I don't need it. If we have long cloudy stretch, it would be nice by about the third day to take some heat in, but the sun isn't bright enough. I would need to heat the water in a very large super insulated tank in sunny weather and draw from it in cloudy weather.
Some solar sites like ..::REvision Asset Management Systems::.. I have visited say this isn't a good matchup due to the btu's the solar would need to provide. Plus, when I would need it the most, mid-dec thru mid feb, there is the least sun to begin with. I notice evacuated tube type collectors are getting pricey. The link is to revisionenergy.com. It works but won't give up on the wrong name.
Good luck in your research.
Dave.
I'd like to use solar for both the hot water and the hydronic heat. As I learn more about it, I'm starting to think they might be two different setups. A large hot water heat storage tank makes sense for the hot water, but I have a hard time thinking that you could possibly store enough heat to matter on the hydronic side, compared to all the heat stored in the concrete already. I'm still in early stages on this, haven't actually done any calculations comparing the heat storage.
I am planning on making my own panels. Commercial panels are pretty pricey. There is a *lot* of apparently excellent information at this site:
BuildItSolar: Solar energy projects for Do It Yourselfers to save money and reduce pollution
This is the collector that looks good right now:
Experimental Solar Collector Using Hybrid Copper/Aluminum Construction
Steve
