century 2028 c29 clutch replacement
   / century 2028 c29 clutch replacement #1
traumaj
century c29
i bought a 2028 century c29 6 yrs ago with a front end loader and i love my tractor it has been wel worth its weight in gold to me i have done evreything from pushing down trees stumps old cars and am diggin a pond with it but after 407 hours of zero maintanence minus oil and filter changes i lost my clutch yesterday no pedal was working started acting like it was loosing its strength then now no clutch at all engine runs grate all else works all hydraulics but no clutch dont have a clue as to where to start to replace. linkage all working up till it enters the tranmission. anybody got experiance changing a clutch in one of these?? motor has to come out right? i have worked on multi million dollar airplanes i know i can fix it . not about to pay dealer to do it... just need some experianced guidence before i go stripping things off
   / century 2028 c29 clutch replacement #2
I currently am in the process of changing the engine and pto clutch plates on my 2035 as well as a shuttle shift fork. The tractor has to be separated between the engine and bell housing. With time and a little patience, it's not too bad.
did you have a book to follow or did you just jump in and take it apart how expensive is the clutch
   / century 2028 c29 clutch replacement #4
Did you try adjusting the clutch linkage? This is a turnbuckle on the linkage just after the pedal. You might be able get some more life out of the clutch.
   / century 2028 c29 clutch replacement #5
As suggested, check to see if you can get some freeplay with adjustment of the turnbuckle. If not, split it at the bellhousing. It's about a full days job to put a clutch in one of these. Figure 10 hours, more the first time around. A good portion of the work is dealing with the loader brackets. If no loader, it's quicker.
   / century 2028 c29 clutch replacement #6
i also have a century 2028 a 2004 year i cannot find a dealer for parts i need a fuel pump cto547ka2 , i would appreciate any information that i can get as i need to us my tractor. the dealer that i bought from no longer sells century.thanks
   / century 2028 c29 clutch replacement #7
Someone answered your "century tractor" thread with dealer info. Maybe you should look at that thread again.
Mark
   / century 2028 c29 clutch replacement #8
I am looking for parts to rebuild the clutch in my Century C29 (2005 model)
Carroll
   / century 2028 c29 clutch replacement #9
Carroll
Call any Branson dealer for a clutch assembly. Or you can find a clutch rebuilder in your area, most big towns have one, and get it to them to rebuild.
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
2008 CAT 287C (A50854)
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
