JD / Massey / Kubota Comparison w/prices
   / JD / Massey / Kubota Comparison w/prices #1
Matt400
West Coast
Don't know if I will pull the trigger on one of these or not and am looking for input..
The prices listed are out the door, sales tax & all with HST,FEL and factory Cab.
I like the 1635 for its HP and width of 64.5" and just so happens its less.
I can get 0% for 60 months with 20% down and a 5 year power-train warranty.
The 3320 is 5.5" more narrow and on our sloped property I figure wider is better. Financing is 0% with 10% down for 48 months
The L3240 is 4.7" more narrow than the MF. Financing is 0% with 20% down and for 42 months. Not sure I would like the brakes on the right side and I don't think they want to work on the price much.
All 3 tractors weigh in about the same around 3500 lbs with the factory Cab and no FEL. The intended use is to rotary mow a 1.5 acre sloped hill and snow removal on a 50'x150' commercial lot with possibly a 6' pusher. I am still looking at used for options in addition to simply putting a plow on my pick-up for snow removal and using a Garden tractor for the mowing.
A new V-Plow and new GT with locking differential is only $8,000 but not sure I want a plow on my pick-up, its an 05 Dodge Diesel and very capable.
Any input much appreciated!
   / JD / Massey / Kubota Comparison w/prices #2
well, for 33 grand you can buy a used tractor and a zero turn for less money. Now you might not get everything you will get with the new tractor though. I dont like cabs. I feel claustrophobic in it, but if I lived in the north I might change my view. LOL. If you could do without a cab you'd save a bunch of money.
I just hate the idea of plowing in the winter while its snowing or raining. Before I set on an open cab I would for sure put a plow on my pick-up
   / JD / Massey / Kubota Comparison w/prices #4
Wow, for 33k I could have bought a whole lot more tractor and more attachments than I did. I guess it's the area but here in Texas I got a 2008 brand new 5103 (45HP) with FEL, shredder and HD box blade for just over 20K. Now mine is an open station and you might be wanting a cab. Not sure what specific requirements you need but an extra 10k for a cab? Again Wow. Just my opinion.
Good luck.
   / JD / Massey / Kubota Comparison w/prices #5
I haven't priced either of the three you asked about but I did recently price a Kubota L3940. That's quite a bit more tractor than the 3240. The phone price I got was 24,500 (no cab). That was without even going to the dealership. I suspect I would get a better deal if i decided to go that route and negotiate a bit.
My understanding was that a cab typically adds about 6K to the price. That would take the price of the L3940 with cab to 30 - 31K.
Based upon that, I would say you definitely need to shop around.
I would also advise you take a look at the Kioti. It's a solid tractor; much heavier and significantly better FEL capacity than the 3 you are looking at for significantly less money. Just something you might want to consider.
Good luck with whatever you choose.
If I take the price of a cab off and the sales tax it looks like this:
  • MF - 22.5
  • JD - 24
  • Kubota - 24.8
So sales tax being over 8% and just under 7K on a factory cab really drives up the price but I can't justify a tractor of this size with no cab. To go cab-less means it would just be a mower and will be parked in the winter in which case these models would not be considered.
   / JD / Massey / Kubota Comparison w/prices #7
Matt, I understand your need for the cab but look at the price differences I pointed out; 24,500 for an L3940 without cab and you are saying 24,800 for a 3240 without cab. There is a big difference in those tractors.
I'm in NC so maybe there is a significant price difference based upon location but I would definitely recommend you check around.
Ask your dealer for the price of a 3940 for comparison purposes. You may find you could buy from out of state and have it shipped to you and still save a bunch of money.
Good luck.
   / JD / Massey / Kubota Comparison w/prices #8
If you want a cab then get a cab. I just know for me that working around the edge of fields & going thru the woods I'd rip the cab off. I understand wanting one though. I think there way overpriced. I think you should check out some used ones. I'd say 12 to 16 grand would get you a good tractor.
Totally agree and is reason for not wanting the Kabota as the dealer is quoting 28.00 under msrp. Not my kind of deal.
I agree, I found an 06 NH TC31D for 14K with low hrs but no cab. I would have to check but I think that one is pretty narrow like a Kubota B3030.
But with that one I would rather be in my pick-up with plow, so the NH would just be a big mower.
Another one I found was a JD 4720 Cab & FEL for 26K with 1500 hrs. allot more tractor for less money but 1500 hrs.
Sedan (A59231)
Sedan (A59231)
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2015 Kenworth T880 QMC 8060R 50 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
