JD / Massey / Kubota Comparison w/prices
   / JD / Massey / Kubota Comparison w/prices #11
those hrs aren't much. Just make sure the maintenance was done IE service records & receipts. I used that same tractor only open station. I loved it. I really would like that one. That sucker seemed like it had alot of power to me. It felt heavy too. I never checked, but if I could get that with cruise control I would definitely consider that one.
   / JD / Massey / Kubota Comparison w/prices #12
Matt 400,
Just to give you an idea a brand new 4520 cab with 1100#'s of weights, mid joystick, rear outlets, updated cruise, rear lighting, rear wiper, epto and telescopic links was $34,000 without fel.
   / JD / Massey / Kubota Comparison w/prices #13
Shop around. Those prices are high, even without the cab.
You might also think about an after market cab.
The Kioti suggestion is a good one. A 35 HP Kioti is under $18K. You can get a 40 or 45 HP cab for that kind of money in a Kioti. Probably true of some other makers as well, like Mahindra, TYM, or Branson.
Sounds like nobody likes any of the 3 due to sticker shock
   / JD / Massey / Kubota Comparison w/prices #16
   / JD / Massey / Kubota Comparison w/prices #18
It looks like you and I are zeroing in on the same type machine - ~35 hp with a cab. While you have been looking at the bigger, established brands, I have been also considering the Kiotis and looking hard at the LS and TYM offerings.
The Kioti seems about $5k less and the LS and TYM maybe $10K less- or a couple of K less and lots more HP.
What I seem to be hearing is that the LS and TYM are quality machines, but the dealer network is pretty weak. Kioti seems to have s olid network set up.
Anyway, I have decided to go ahead and get quotes on the MF and Kubotas, as well and should have those this afternoon.
Just as an FYI- the LS U5020C with 47 HP and cab is about $30.5K. It doesn't have a hydro, but that seems like a heckuva lot of machine for the price. And I am pretty sure LS/LG makes a pretty significant percentage of all the tractors/parts on the current market. Can they get a reliable dealer network set up? That's the scary question to me.
The TYM has a 43 Hp with cab and FEL for about $25K (shuttle shift). But the only dealers I find are over 140 miles away or do not answer the phone.
I have a quote for a Kioti DK35 with cab FEL, shredder and box blade at $28.5 (5k down and 72 mos 0%) or $26.5K cash.
I am awaiting quotes on comparable Kubotas and MFs and will report back what I find, either here or in my "cab and a/c as top priority" thread.
I appreciate all input on the comparative qualities and abilities I realize everything I have listed may be apples and oranges, so its kind of difficult for a noob like me to cipher it all out.
   / JD / Massey / Kubota Comparison w/prices #19
Just remember the Kioti DK35 is a 38 HP tractor so make sure you get comparables for price comparison. You will see JD, MF or Kubota will not even be in thge same ball park.
I agree with E/S that you generally get what you pay for but sometimes you pay for a lot more than you get!! That seems to be the case with the JD, Kubota, MF and NH tractors.
Also remember when you comp a kubota, it will take a Grand series to compare to a Kioti. There are some trade offs there. The Grand has a newer transmission wich has more features but the Kioti will still be heavier and have a stronger FEL.
   / JD / Massey / Kubota Comparison w/prices #20
I just got a quote on a MF 1635 with cab and FEL for $26K cash. The dealer raved about the FEL and cab quality, but I have not seen it. This sounds more competitive than I had thought it would be. But MF was so far off my radar, I need to do a lot of research on them.
Also, I could step up to the 1647 for another $2500
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
John Deere 980 Field Cultivator (A59814)
John Deere 980...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
Forklift (A59228)
Forklift (A59228)
44052 (A55852)
44052 (A55852)
