Bird's mouth cuts - necessary?
   / Bird's mouth cuts - necessary? #11
That is a form of a gable roof. You will need ceiling joists to keep walls from pushing out or trusses. If it is not an optical illusion I believe the plate height on the front wall is higher than the plate wall on the rear wall. If the span is not to great your joists could go level from front plate height to back rafters. I still would cut birdmouths. How wide and deep is your building going to be? I would guess that picture to be somewhere from 4/12 to 5/12 pitch.
   / Bird's mouth cuts - necessary? #12
You're right that ceiling joists would be the strongest way to hold the walls togeather, but it's not a must. If he uses a strong ridge pole with cripples to support the ends of the ridge pole (puts the load on the walls), it should be fine. Also a good anchor from rafter to ridge pole is important.
   / Bird's mouth cuts - necessary? #13
I agree, your right, could be done that way.
   / Bird's mouth cuts - necessary? #14
I agree you should make a quick study of the use of a framing square...be aware not all squares are the same...some have random (garbage) information rather than useful rafter tables etc....
you need to learn how a rafter is measured before you can make any seat cuts the "birdsmouth" is actually the point the seat cut makes and one of the main reasons to make them is to help keep the framework square and true...
Be sure to pick a slightly crowned board to cut your rafter pattern since most of the boards will have some crown...by using a pattern to mark all the top and seat cuts...you can use the "birdsmouth" to keep the wall straight with the ridge (birdsmouth is the exact outside edge of (wall) frame)
If you are using only 2x4 for reafters the adjacent ceiling joist or ties makes the "seat" aas there is no meat to cut one...usually a wedge is added...
   / Bird's mouth cuts - necessary? #15
   / Bird's mouth cuts - necessary? #16
One of the reasons for the bird's mouth is so that you have more of the rafter sitting level on the top plate. Bevelling the top plate/header/load beam or whatever the rafter sits on will work esp if you run celilng joists and but up to the rafter and hard nail.
I personally would not build w/o the bird's mouth, whether gable, shed, or hip roof. The more you can adequately/accurately fasten the parts, the stronger the entire unit will be.
If you do the bird's mouth, don't cut any deeper than 1/3 of the rafter's width, it will weaken the board. I always do one inch depth, sometimes 1/2'' on largers rafters.
   / Bird's mouth cuts - necessary? #17
I have had great luck with rafters/birds mouths with a Swanson speed square. Included with the speed square is a little book that makes birds mouth cutting a snap. Good luck.
   / Bird's mouth cuts - necessary? #18
In my part of the world the county building inspector runs the county and he doesn't even look at a print unless he sees a state certified engineers stamp on it. The neighbors tried to get away with out a permit and their efforts are now setting in a rubble pile waiting to be hauled off. It don't matter what you want to drive a nail into I can't happen unless the inspector says it's okay. bjr
   / Bird's mouth cuts - necessary? #19
So based on this we are all just renters ! even if we have our farms paid for we are only tenants as long as you can not do what you want to with your property especially in a rural area and on top of that we pay our rent in the form of every increasing taxes.
   / Bird's mouth cuts - necessary? #20
About 20 years ago, a friend sent me an article from the newspaper in Seattle that tried to explain how much extra a building lot cost because of all the regulations. At the time, it was several thousand dollars. No telling how much now.
I've sort of been curious what the concern is about making the bird's mouth cut. Once you get the hang of it, it's not difficult. Structurally, the metal plate connectors are much more resistant to pullout and uplift.
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
1998 SHERMAN +REILLY 6048 SINGLE DRUM LINE PULLER (A50322)
1998 SHERMAN...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
1985 Chevy C8500 Auger/Derrick Truck (A50323)
1985 Chevy C8500...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
