eBay/Craigslist 54" blower on Ebay for 7000 series
   / 54" blower on Ebay for 7000 series #1
OhioGuy
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
   / 54" blower on Ebay for 7000 series #2
Anyone have a picture of how these hook to the 7000 series? Says it comes with a front hitch kit.....does it have a manual lever to raise and lower then? Or does it connect to front loader arms? I have a 7272 with front loader and am interested...thanks
   / 54" blower on Ebay for 7000 series #5
Not sure if it will adapt to the older 7000 series. Was designed for the 6000 series, loader comes off and hitch bolts on.
   / 54" blower on Ebay for 7000 series #6
I've been looking for"front" a blower for my 6284 for some time.
I currently have a great Pronovost 3pt. but 'getting too old to "keep looking back"...
I'm a little reluctant because one may be buying an "orphan".
Does anyone know if parts would still be available ? ( future)
I've also been having thoughts about getting a different tractor all together. The 6284 has been pretty good so far but I've got a lot of hills on my lane ( asphalt). She get a little hair raising sliding down some of them backwards !
Thanks for your comments.
Graybeard
   / 54" blower on Ebay for 7000 series #7
I went to the Cub Cadet website and put in the model number in the parts search and parts are available.
   / 54" blower on Ebay for 7000 series #8
Graybeard,
Have you hung any suitcase weights on the front? I have been using my 6284 all winter to pull trailer loads of firewood from my woods and have several steep grades. I hung 5 40 lb weights on the front of my tractor and it really improved where I could go - even is deep snow. With the weight it sounds like you have hanging on the back front weights should really help.
The one problem I have had to be careful about is coming down the inclines pulling a full load. The trailer wants to push the tractor and it will sometimes push the rear sideways at which point I have to speed up a bit to keep things straight. It gets a little exciting keeping the rig from jackknifing.
JN
   / 54" blower on Ebay for 7000 series #9
Graybeard,
JN
I've got a loader on the front.
Can you use the weights on the front, with the loader on ?
I'm not sure what I'm going to do.
I like the machine(6284) but with the local drl. going under, I may look to something else. For darn sure, I want to be able to "stick" to the hills.
Steiner ans Ventrac look pretty inviting but pretty spendy as well...
I've got a quad with a 55" blade for the snows up to 8 or 10" but soon you run out of room to push it.
The Pronovost is a heck of a blower. I'm just not looking to right way for my stiff neck !
GrayBeard
2023 Ram 4x4 Pickup Truck Bed (A49461)
2023 Ram 4x4...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
