Need BX 24 Diagnosis
   / Need BX 24 Diagnosis #1
DickS
U.P. MI
JD 265, Kubota BX24
Went out today to move some snow around and had a first time problem occurrence. Engine has 400 hours. Fuel tank full.
Outside temp about 20F, engine had run for 10 minutes. Suddenly, there was a loss of power with black smoke coming out the exhaust. The power loss was steady and persisted for about 30 seconds and then disappeared. It ran good for about a minute and there was one slight misfire thereafter. I ran the engine full throttle for about 5 minutes with no recurrence of misfire.
Any ideas?
   / Need BX 24 Diagnosis #2
Check the air filter, then add fuel aditive for to keep it from gelling, you may also want to change the fuel filters
   / Need BX 24 Diagnosis #3
Are you gellin'? Sounds like gellin'. Put some power service in it and lax up on the gellin':D.
   / Need BX 24 Diagnosis #4
I vote that there is a restriction in the air intake. The black smoke indicates unburned fuel.
   / Need BX 24 Diagnosis #5
I have had a similar experience when plowing, usually when hitting a pile and then reversing. I plow in high range, and have actually lugged the engine trying to back out suddenly, It ran smoking and lugging untill I let off the pedal. It then responded perfectly. I cannot explain why, it may be the seat switch cutting it off just long enough to drop rpms while going under a load?
I do hit piles hard enough to lift me from the seat.
Or you could have sucked some powdery snow into the airfilter. The black smoke indicates plenty of fuel, too much infact for the conditions.
The part about the failure to operate properly that is strange is the sudden appearance and disappearance of the misfire. There was no transition at all. If it was an air obstruction, wouldn't there be a slow degradation in performance rather than sudden? Does the possibility of an injector being stuck open make sense?
   / Need BX 24 Diagnosis #7
I think you were encountering some waxing in the fuel. Did you add anti gel to your fuel so its treated ? The issues you described sounds like you had some waxing in the lines due to cold temps just before it goes to gelling. "IF" you did add anti gel chemicals, then you will need to add a splash more as you are not adding enough.
I see you are in upper MI, your fuel should be already a winter blend unless its leftover from summer ? Or are you buying bio diesel ? That would be the exact same symptoms.
   / Need BX 24 Diagnosis #8
My BX 23 manual says i can use summer blend at temperatures above 14 degrees.
   / Need BX 24 Diagnosis #9
sounds like fuel gelled, add anti-gel & change the filters.
New 2025 NextGen 7x20 Equipment Trailer (A51573)
New 2025 NextGen...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
