WTB - Kubota BX2763A plow and quick hitch setup.
   / WTB - Kubota BX2763A plow and quick hitch setup. #11
Thought I would post here first before hitting CL and eBay...
Moved on to using a snowblower the clear the driveway (Honda HS1132, awesome machine!) So I'm willing to part with the blade:
BX2763A Hydraulic angle 60" blade,
BX2762 Skid shoes,
B2766 Rubber edge
BX2751 Quick attach subframe
The rubber edge is mounted but the buyer will also get the steel edge. Very good condition, only used to clean my driveway the past few years.
$1250, in NJ.
   / WTB - Kubota BX2763A plow and quick hitch setup. #12
Joe would you sell me just the hitch? And could you ship it at my cost?
   / WTB - Kubota BX2763A plow and quick hitch setup. #13
The whole thing is already sold and gone.
Thanks,
Joe
   / WTB - Kubota BX2763A plow and quick hitch setup. #15
ok im looking for a bx2763a-60" with skid shoes and quick hitch. thanks:thumbsup:
   / WTB - Kubota BX2763A plow and quick hitch setup. #16
Shopping in spring? Good move!!! Still, they're rare as hen's teeth and priced accordingly. Awesome implement though, completely awesome.
   / WTB - Kubota BX2763A plow and quick hitch setup. #17
Thread resurrection from the dead - in case anybody is still looking for one of these - there's one for sale on Craigslist - in Nude Hamster -for $950:
Kubota 60-inch 4-way Hydraulic Plow
   / WTB - Kubota BX2763A plow and quick hitch setup. #18
It was unusually warm here in CT today, so I thought it would be wise to switch out the front loader for the BX2763A plow blade for the first time. We've only had one storm so far this year and I wanted to try the regular bucket first, just to see what how it would do. The dealer told me not to get the plow, that the bucket would handle snow just fine, but I like to use the right tool for the job, so I ordered the plow with my BX. The bucket did ok, but it could only push snow straight ahead. My front drive is 150' long and I had to make several passes to get it clean due to the side spillage out of the bucket. So now, on to the plow.
First I read the instructions on how to detach the front loader arms. It was actually easier than I thought it would be. Drop the loader parking stand, lock it in place. Pull the loader pins. Curl back the bucket (I had my pallet fork attachment on, but same difference), the loader arms rise out of their cradle joint, disconnect the hoses after relieving pressure and back away. So far so good. Next I went to mount the quick-attach unit to the tractor, figured out that I needed to remove the BX front guard to attach the quick attach. Wondered why on earth the guard was not designed to allow for quick attachment of the quick attach??? Anyway, took 25 minutes to attach the (I won't say it again) unit to the front frame. Got it mounted, connected the hoses (First and Last couplings) then started up the BX. Hydraulic fluid poured out. Turns out the hose couplings were only finger tight. Who would send out a hydraulic attachment with finger tight hydraulic hose connections? I spent some time tightening everything up and this time it worked. QC unit raised and lowered as expected.
So now on to the plow itself. Again, both QC couplings were only finger tight. Went through the tightening process and hooked them up. Now I could raise, lower, and swing the blade right and left. I was still getting some fluid drips from the coupling threads so I relieved pressure and tried to tighten the plumbing even more. I still could not get the leaks to completely stop. I've heard you're not supposed to use teflon tape on hydraulic lines, is there something else than can be used? I worried that I'm going to snap the elbow fitting if I apply any more force. I'm pretty sure I need to top off the hydraulic fluid. I left the BX in the gravel parking area tonight, so it would not leak in the tractor shed. I'm going to call the dealer tomorrow. Did anyone else get a new plow with loose QC couplings?
   / WTB - Kubota BX2763A plow and quick hitch setup. #19
They make a liquid paste "Teflon" that works great. Many places sell it.
   / WTB - Kubota BX2763A plow and quick hitch setup. #20
Any sealant that specifically states that it is compatible with hydraulic oil is fine. The problem with Teflon tape is small pieces tearing off and getting into the system.
John Deere (A50322)
John Deere (A50322)
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
Kelly Ryan Bagger (A50774)
Kelly Ryan Bagger...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2005 Mack CV713 Granite T/A Roll-Off Truck (A50323)
2005 Mack CV713...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
