BX2660 FEL rescues 2003 Dodge Dakota 4X4
   / BX2660 FEL rescues 2003 Dodge Dakota 4X4 #1
JOHNTHOMAS
Super Member
Somerset, Ky
F2690 4WD RTV X1140 MX5400 HST ZD1211
I know there was some question on a recent post as to which was saving which. A BX pulling out a Dodge truck or the Dodge truck pulling out the BX?:D Well today when I came home I couldn't get my Dodge truck up my drive because of snow covered ice on my drive. Had to park truck in yard, go get BX2660 and clean drive till I could get the truck up the drive. For first time even my BX spun coming uphill on the drive when I tried scrapping the drive. I had cleaned it coming up and going down before today but couldn't do any cleaning coming up because it was so slick. It would come up fine but not with bucket down. Gary (Barlows parts man)told me today that my right rear tire on my truck was slick. I knew it was near replacement but didn't realize how bad it was until today. So, 2 new tires in my near future.
   / BX2660 FEL rescues 2003 Dodge Dakota 4X4 #2
I use my bucket to scrape/plow my driveway all the time. Whats nice about it is that it cuts right through the hard icy layer that the vehicles compacted. Gets right to the pavement so any little bit of sun will warm it right up and naturally clean it up.
When I got my BX2660 back up to it's house I noticed my temp gauge was in the red. I about panicked. I raised the hood and checked to see if the fan was turning, it was and I didn't notice any feeling of excessive heat. It's like 30 degrees out side with strong wind. I turned key off and back on and the needle came to the mid point. Turned it off and on a few times and needle shot straight to mid point. Don't know what caused it.:confused:
   / BX2660 FEL rescues 2003 Dodge Dakota 4X4 #4
stuck closed thermostat ?
If the engine had been hot or cold then probably but it was neither. The gauge was showing in the red and when I turned it off and back on immediately it went to center and I did it several times and always back to center. I believe it was an electrical/guage fluke. I'll keep an eye on it. The fuel guage has been bad on this tractor since I got it, don't know if it's the float or the guage. I may have Barlows fix it one day but not a real problem for me. Now 2 guages will inspire me to trailer it to them. Thanks for the input.
   / BX2660 FEL rescues 2003 Dodge Dakota 4X4 #6
Why don't you just wait a few months and trade it in? :) :)
   / BX2660 FEL rescues 2003 Dodge Dakota 4X4 #7
I have a new bx2660 the fuel gauge did the same thing shut it off turned it back on and it worked. must be something wrong with them.
LBrown59Re: BX2660 FEL rescues 2003 Dodge Dakota 4X4
Quote:
Yeah sounds like the perfect solution to me;).
That doesn't always work. I traded the BX2350 rather than fix the one bad front rim/tire and ended up with the same problem with the new BX2660.:)
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
SCAN TO RECEIVE TEXT UPDATES (A51248)
SCAN TO RECEIVE...
John Deere Gator 6x4 Utility Cart (A51691)
John Deere Gator...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
