Massey 1145 crankshaft needed
   / Massey 1145 crankshaft needed #1
DavesTractor
Elite Member
Red Bluff, CA
Changes often!
We took in trade a Massey 1145 with a busted crankshaft. I believe this is an Iseki built tractor. Massey no longer can get a crankshaft. Any ideas on where to get one? If we can't we may part it out, too bad as it is a fairly nice machine. Has anyone just repowered one with a different engine with any success? Thanks, Dave
   / Massey 1145 crankshaft needed #2
How about a new Iseki diesel??
df
I'll give that a try, might as well exhaust all resources for a new crank before we take more drastic measures.
   / Massey 1145 crankshaft needed #7
try a 1440 massey should be same motor as 1145 or agco unde challenger line as they rebranded many of them crankshaft break rare as they were very durable a good machine shop can weld and return it to a good part trick is need to find a very good shop not a run of the mill one
That's the sort of info that is very valuable, thanks.
Good luck. Keep us posted.
df
We have a great contact in Japan, and they contacted Iseki and the part is not available through them. That makes sense, because if they had it, they would surely sell it to Massey. Looked for a used crank or engine, and no luck either.
We will check into the crankshaft repair option. If that doesn't pan out, we will have no choice but to part the tractor out, or repower it with a different engine.
If any of you guys have further ideas, we are open to suggestions.
This is a 1992 tractor, it's not an antique. And it is a Massey, not some obscure brand. I am surprised we can't get a major engine part.
   / Massey 1145 crankshaft needed #10
That is an issue with Iseki. I wonder why they did that??
df.
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
