Forks for FEL
   / Forks for FEL #12
jimcolt - how much for a set?
Jimcolt: Post the price for all to see. I have a set already but I also have another tractor at or going to be at another location.
   / Forks for FEL #13
I sell them for $299. The usable length is 44", you can bolt a 2 x 4 piece of wood to the upright, they have been tested at 2000 lbs....17" out from the bucket. Weight is approximately 62 lbs per fork. The standard clamp slot fits the kubota bucket (4310 tractor) perfectly.....I can custom cut the slot if a profile of the edge of the ucket is provided.....from the cutting edge back 6".
I have used this design around the farm for two years.....can't break them! I will sell just the clamp assembly if you want to provide your own 2 x 4 tubing for the forks...and do some welding. $79 per clamp. Those prices are unpainted. I hope I don't get busted for advertising.....I was just showing a good fork design that anyone with a set of torches and a welder can build.
Jim
2003 KOBELCO SK235SRLC EXCAVATOR (A54607)
2003 KOBELCO...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
