Dozer vs Excavator-need opinion
   / Dozer vs Excavator-need opinion #21
An excavator will leave a lot of holes from the root system. There will be a lot of "destruction" with an excavator too. Those need to be backfilled and packed down, probably with a blade.
Another issue is the slope of the land, if any. A dozer is more stable on hillsides than an excavator.
Ken
Ken, my experience with small trees as described leaves hardly a hole. Yes, some small ones but these are easily covered up with a side sweep of the bucket in short order. One of the largest advantage of an excavator is it is able to pivot and cover a large portion of ground without moving. I have seen a 1 yard bucket excavator out pace a 2 and 1/2 yd loader when filling dump trucks as a result. You raise a valid issue with the lay of the land of which I do not know. Out where I live, in the late 1800's they would just use the trees as fence posts. I have barbed wire coming out of the middle of trees that are 15" round and because a tree grows height wise mostly from its crown, the fencing appears to be in the same place on the tree they placed it over a hundred years ago. Just that now the fencing comes out from the middle of the tree.
   / Dozer vs Excavator-need opinion #22
Ken, Arrow,
South Louisiana is flat, real flat.
MarkV, I think either the dozer or excavator can easily clear the fence right of way, my thought was the excavator could bury it quickly.
   / Dozer vs Excavator-need opinion #23
Have you though about a skid steer with a cut/mulching head on it?
   / Dozer vs Excavator-need opinion #24
This is a very good idea could make very quick work of it
only problem would be stumps left behind
I've ownd a dozed and doing finish quality work is very hard to get right excavator on the other hand much easier for average operator
if you don't need to stump I like the skidsteer mulcher idea if you do I've found excavator to just be a bunch easier thumb a must for dealing with trees
Joel
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
1268 (A50490)
1268 (A50490)
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
