running just below the red ... OK??
   / running just below the red ... OK?? #1
Gedfish
Member
Purga / Mutdapilly, Australia
Ford 4110 Series 2, 1988 Kubota B7510, 2006
Hi there. Is it OK to run the diesel engine just below the red zone (still in the green) or is it better to keep well up in the green? Thanks, Ged
   / running just below the red ... OK?? #2
I won't let mine get there for very long. As soon as I see it is getting up that high, I will stop and clean the screen out so that the temp drops back down to the normal range. If it does it w/o a load you might want to try a different gauge and/or sending unit. If it truly is running that high you might want to make sure the thermostat isn't sticking or the radiator itself isn't clogged.
   / running just below the red ... OK?? #3
Use only the power you need to get the job done. If your up near the red for most chores maybe you should tackle them a different way or take a little longer.
   / running just below the red ... OK?? #4
Absolutely. First thing is to find out why it's getting that close to red in the first place.
   / running just below the red ... OK?? #5
I don't like to,for I feel its harder on the engine in time also on attachments...slow and steady better results.
   / running just below the red ... OK?? #6
Are you talking about the temperature or tachometer?
   / running just below the red ... OK?? #7
I'm not 100% sure, but I don't think there are any green or red zones on my tachometer. Temp gauge, yes. Tach, no. I'll have to check when I get home.
EDIT: There's no red zone on the tach. Also, most operator's manual indicate where the temp gauge needle should be for normal operations, usually in the middle of the green. If a tractor that had always been in the middle of the gauge suddenly jumps to just below the red zone and stays there, that indicates a problem to me. In other words, if just below the red becomes the 'new normal', there's a problem.
   / running just below the red ... OK?? #8
It doesn't matter tach., or temp. Use just the power you need to get the job done.
I should clarify - I mean temperature. Our tractor is used by a number of people across 2 properties. One operator is a little reluctant to clean the screen, and the rig heats up a bit. I have some experience fixing diesels (I service my Toyota ute (pickup) and our John Deere X495. Replacing water pumps, timing belts, removing fuel pumps etc. I was hoping someone would say that running up the temp a bit really doesn't matter. I know older diesels do not have the finer tolerances that the newer engines have because of emissions requirement. Still, like the 3 Bears - I figure the porridge is best warm & not too hot or cold! Cheers, Ged
   / running just below the red ... OK?? #10
Ged, you really need to know what temperature the redline is to make a determination. To me, the redline says the coolant is low or could be boiling off or leaking. Running consistently up to the red, but staying in the green, would seem to be fine. Your engine probably runs very well in that range. I would expect 85ºC to 100ºC to be within the normal range and probably around 110ºC to 120ºC to be the redline zone where pressurized coolant would be likely to boil off and engine oil would rapidly start to deteriorate. Close to the red, but still in the green is "good to go" in my book. Green is green no matter if it is high green or low green.
2021 JOHN DEERE 6130R LOT NUMBER 46 (A53084)
2021 JOHN DEERE...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2017 Chevrolet Silverado 1500 (A52377)
2017 Chevrolet...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
