2810hst hydraulic fluid leak
   / 2810hst hydraulic fluid leak #1
gav64
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
I have a 2810hst with about 450 hours. Hydraulic fluid is leaking out the reliefe valve located under the seat on the 3 point arms cover plate. It is a fitting that has a small bolt with a hole drilled though it. The leak seams to be coming from the threads of the fitting not the relief screw, the threads do not appear to be tapered. I have tried sealing the threads with teflon tape, locktite blue and loctite thread sealer, neither worked. It only leaks when you are moving not idling and leaks at a pretty good rate. Any ideas out there. thanks Glenn
   / 2810hst hydraulic fluid leak #2
Are you over full on hydraulic fliud?
   / 2810hst hydraulic fluid leak #3
Had the eaxct problem with my 2810. Dave's Tractor in Red Bluff traced it to the vent being plugged on the lower filler plug. The plastic one where you add the fluid. Not one drip after this fix. Hope this helps
thanks wallace and Thomass88, i did drill out the vent on that fill plug it appeared to be plugged however I have not had the time to run the tractor lately .time and massive amounts of rain I will keep you informed as to how i make out
Thomass38, ran the tractor hard for a day, not a drip, thanks for your help. File this one in the back fof your if you are a 2810hst owner!
1264 (A50490)
1264 (A50490)
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
Massey Ferguson 9250 (A52748)
Massey Ferguson...
Has Charger with it. (A51694)
Has Charger with...
