Snow Attachments Snow Blower Packing Up With Snow
   / Snow Blower Packing Up With Snow #11
try lining your chute with slick self lubricating plastic. I have an erkstine blower on a cat 277b and it has that. Its seems to work well. :thumbsup:
We got hit with another quick, strong storm two days ago. The temp never got lower than ~25 deg F, so the snow was really heavy and wet. Oh, the joy of spring mud. Anyways, *this* time I made sure to use a liberal amount of silicone spray lube in the chute, impeller, auger, etc. That made a HUGE difference - I'm convinced now.
In one of the posts, someone mentioned some kind of slick plastic - anyone have more info on that stuff?
   / Snow Blower Packing Up With Snow #13
Well I can relate to the wet snow as I live on the east side of the Sierras here in Reno/Mt Rose HWY area. What has worked for me at times is to let the wet snow freeze over night and get at it early the next morning. If you can. :(
   / Snow Blower Packing Up With Snow #14
try this. Cut it into a correct width strips and line the back face of the chute. Rivets should hold it in very well. I find that if the chute does not clog nothing else does either.
UHMW Full Sheet | U.S. Plastic Corp.
   / Snow Blower Packing Up With Snow #15
I used a piece of plastic they use for the hockey rink boards .White plastic very durable and slippery:thumbsup:
   / Snow Blower Packing Up With Snow #16
A 3/16" or 1/4" thick sheet of UHMWPE (ultra-high molecular weight polyethylene) attached to the long curved surface of the chute with flat head screws, counter sunk so they're flush. UHMWPE is tough, strong, abrasion-resistant and slippery.
   / Snow Blower Packing Up With Snow #17
Lee Valley tools sells smaller sheets of this stuff. It is basically what is used around a hockey rink. Very slippery when wet. It comes in different sizes.
Just type in Lee Valley Tools, under item search type in UHMW. You will get 4 results for this. Take you pick of what may work best for you.
BTW-Lee Valley is a mail order catalogue from Canada nad sells high quality woodworking tools.
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
More info coming soon! (A50322)
More info coming...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A56138)
1999 INTERNATIONAL...
2007 International 4300 (A53314)
2007 International...
