Zerk Fittings- Kubota L3400
   / Zerk Fittings- Kubota L3400 #1
casboating
Slidell, La
Kubota L3400 HST
I need to replace two zerk fittings on my FEL. Can someone advise what size
the fittings are?
Thanks in advance,
   / Zerk Fittings- Kubota L3400 #2
the fittings are?
Thanks in advance,
Best bet is to pull them out and take them to your local hardware store. My guess is they're 1/8th pipe thread (or 3 mm if metric), but guesses aren't always correct.
   / Zerk Fittings- Kubota L3400 #3
Mine are 1/8 pipe thread, at least that size fits in the hole. I had to replace one early on.
Chilly
   / Zerk Fittings- Kubota L3400 #5
I had one bad zerk on my FEL on my L4400HST. I removed it and showed it to the dealer. The parts guy opens a drawer and hands me one from loose stock--on the house. As said earlier, best bet is to take the original out for exact replacement.
   / Zerk Fittings- Kubota L3400 #6
Be aware that in my case (about 4 times now) when I have broken a zerk off I've had to use an Easy Out to remove the threaded part remaining in the hole before I could reinsert a new fitting (obviously)...so, be prepared that you, too, may have to remove some busted parts before putting in a new one.
   / Zerk Fittings- Kubota L3400 #7
mine are 8mm
8mm (.3149") is just over 5/16ths (.3125"). That's a right big zerk fitting.
I think you're confusing the wrench size (required to remove the fitting) for the thread size. A 1/8th pipe thread does look bigger then 1/8th inch.
   / Zerk Fittings- Kubota L3400 #8
The most common sizes are 1/16 and 1/8 NPT, the nipple itself is the same size. The check ball and spring came out of mine, replaced it soon after.
Chilly
   / Zerk Fittings- Kubota L3400 #9
My L35 zerks are either m10x1. or m10x1.5
one pack of ten, with shipping cost less than $10.00 at McMaster-Carr.McMaster-Carr
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
2302 (A58376)
2302 (A58376)
2017 Ford F-250 (A55973)
2017 Ford F-250...
1708 (A58375)
1708 (A58375)
2018 Knap Heide KTEC88-McCoy24.5 SP Flatbed (A58216)
2018 Knap Heide...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
