RayCo
- Joined
- Jul 24, 2005
- Messages
- 1,031
- Location
- Chester County, PA
- Tractor
- Kubota BX24, Case 580 Super L
Hi there. Most of my property is sloped, and I had a need to create a flat area for a gazebo and some decorative vegetation. The area I needed to flatten would be approximately a 16' diameter circle, where the drop in height from top to bottom is about 2'.
The approach I took to do this was to mostly use the backhoe on my BX24, digging the 2' at the top of the slope and gradually digging less as I approached the bottom. After the digging was finished, I went over it with the box blade as best as was accessible. It all came out surprisingly better thatn I'd hoped, and I'd say it took me about 8 hours total.
If faced with the same requirement, would you do this same thing or do something different? I did find myself thinking at one point that it might have been faster just to use the box blade only, but I wasn't confident enough in my box blading experience, so stuck with the backhoe.
