LD1
Epic Contributor
I can't speak on behalf of the mahindra but the I have a L3400 and find it to be very capible.
Don't get hung up on specs. Test drive both tractors and let that be the deciding factor. The Mahindra total weight is about 50 lbs less than the kubota. So I honestly don't know what an extra 300lbs lift @ the bucket will gain you. I know on the 3400, ballast becomes the limiting factor. The tractor has with ability to lift the rears off the ground with a 5' mower and loaded tires. They could put a 4000lb capicity loader on it for all I care, Its not like it can actually lift that much unless you acnhor the back down.
I will also reccomend comparing apples to apples in regards to the loaded tires. Find out how much more the mahindra will be to load them. You will definatally want it. Right now their is about a $1500 price diff. and geting the mahindra tires filled will eat into some of that.
