Manual vs Hydrostatic
   / Manual vs Hydrostatic #1
FallbrookFarmer
Fallbrook,Ca
Satoh Beaver,Buck,Iseki Farmbos
I am looking at a Kubota 2400 that has a Hydrostatic trans.
Looking for opinions for those who have had both manual and hydrostatic, Obviously it's a lot easier operating, but how about reliability? Have any of you, had Hydro and gone back to manual?
   / Manual vs Hydrostatic #2
I've seen both overused and they both hold up well with proper fluid changes. The clutch often will be the cost part that a hydro doesn't have and some only get limited life do to there use. This is where hydro's will hold up well as a cost basis.
Hydro's are the efficient on PTO work vs the gear drive.
   / Manual vs Hydrostatic #3
My Kubota B1750 hydro is 22 years old and has done 5500 hours - so they last quite well. Previously I had a manual Ford 1210. I would NEVER go back.
Apart from heavy draught work like ploughing, hydros are best - esp for top work and loader work where immediately variable speed is desirable.
I wonder if you will find anyone who has reverted - except on ground of going to different model range?
J
   / Manual vs Hydrostatic #4
It is almost a religious issue - see other threads, you can search for them faster than we can all rehash them.
ONE point that was a surprise to me was a recent claim that hydro tractors can overheat their trans oil if not run WOT (or WFO, as I think that poster put it).
This maybe only applies to some brands, some models, but it would be worth checking on for the specific make/model you have in mind before laying out MONEY.
Boy!, Here I try and post something non-controversial, and immediately get into religion:)
Sorry not familiar, with WOT-WFO, should I not ask?
   / Manual vs Hydrostatic #6
WTO=Wide Open Throttle
The HST is very reliable. My previous tractor was a Kubota B8200. It was made in 1985. I got it in '99 with 425 or so hours on it. I sold it a couple months ago with 1250 hours on it. Not a lot of hours, but 25 years old. Worked like a champ. Kept filters and fluids changed by the book.
Kubota only made the B2400 in HST, I think...
Both trannies work well(gear, HST). Both are well proven with decades of use.
Some people like HST, some gear. They both are good. Some folks like pickups with auto's, some with sticks. Both are good, but subjective based on preference and experience.
I like HST. But, I would still try both before you buy.
Just remember, most HST are operated similar, but there is a plethora of gear shift style; ie standard, shuttle, glide, ect.
Oh, just as a side note, all the CUTS I see at rental yards are HST... The L35 I used to rent on occasion was a GST(which I kinda liked too).
   / Manual vs Hydrostatic #7
Wide Open Throttle.
Errr, a VP might express the other one as "Wide Friggin' Open"
There is also the same money vs same base tractor comparison basis.
Which did you have in mind ?
e.g. for same base tractor you pay more for hydro, perhaps as much as one implement.
For same money you might get the next size up in a gear tractor.
So yes, it might be like studying comparative religion (-:
He want's $6800 for it.
Might be willing to take some or all of my "fleet"
(Satoh Beaver w loader, Satoh Buck, White Field Boss w Loader) in trade.
I like the Kubota as it has 25hp and would be able to use more implements etc.
But then I think, by having 3 tractors and can set each up to do different jobs, and not have to worry about changing out imps all the time.
   / Manual vs Hydrostatic #9
I think that there is/are manufacturer(s) of another colour whose hydro units have a somewhat lower reputation for reliability (at least in UK - although my local dealer swears that was with the older 4000 series and not the current 20 series).
However as you mentioned Kubota in particular, I think you can ignore other manufacturers problems - and as I say my unit has 5500 hours - and I tend to run it at 2000 RPM, not WTO - but I do remember to clean out the oil cooler when I do radiators and I do use proper oil not universal.
However, as others say, why not try to try both?
J
J
Am looking at a used tractor from a small scale seller
When I look at the price of new tractors, I get vertigo:)
BTW On a totally different subject, If you don't mind me asking, Do you have BUPA or straight NHS?
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
PETERBILT 388 CAB (A53843)
PETERBILT 388 CAB...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
Mobile toilet (A53424)
