Is an FEL and Backhoe Worth It?
   / Is an FEL and Backhoe Worth It? #1
robertwhite
Going to be getting a 35+hp tractor (think Kubota L4400 or so) and when comparing the prices of a base tractor for doing mowing, hogging, post holes, etc., versus the base tractor and then adding the FEL, quick release, and backhoe the price skyrockets another $12-14K.
Doesn't it make more sense to just get a used TLB for say $8-10K?
TLB would have much greater reach and capacity, no?
What would be the pros vs cons of getting a tractor set up or the used TLB?
Tractor would likely be new as I would keep it for a long time.
   / Is an FEL and Backhoe Worth It? #2
Get the tractor w/loader. Mow grass with a zero turn, Wait to see if you really need the backhoe.
I absolutely need the backhoe. Using a zero turn has been discussed, but the land is not perfectly flat so speed would be diminished and buying a ZTR AND a tractor w/bucket kind of defeats the purpose of the tractor.
We are talking about mowing 7+ acres and hogging 7+ acres, plus all the normal chores of a small farm type property.
   / Is an FEL and Backhoe Worth It? #4
depends on what you need, I've got a 48 ford that likely has more hours then most compacts will ever have and it has never had a loader or hoe. Problem with the older TLB is maint and repairs. they can suck up a lot of savings real fast, and sitting hurts them more than running in most cases. I too would go with the loader and wait on the hoe, thats what I did but I now have both so maybe I should have just bit the bullet to start with. I would say the hardest part of buying a tractor, compact or otherwise, is realisticly looking at your needs, and choosing the tractor and implements acordingly.
Good luck with your purchase.
   / Is an FEL and Backhoe Worth It? #5
There is no way you can do chores without at least a FEL. The BH can be had later or just hire out the odd jobs you need it for. FEL?? YES! BH? Mabybe..
Chris
   / Is an FEL and Backhoe Worth It? #6
Loader is a MUST. Back hoe is a bonus. Rent one for a day if you have the need. Guaranteed, you will be stealing the kids milk money to buy one.
I bought a used hoe and made brackets to fit my application. Bought a 611 Bradco for 4k, used very little. I wouldn't part with it.
   / Is an FEL and Backhoe Worth It? #7
Look at a used tractor and a new backhoe. There has been a lot of improvements in backhoes in the past 10 years. Just make sure the tractor you get has the hydraulic flow you need otherwise you will be buying a pump also. You need a loader if you are going to have a backhoe. You are going to spend some money either way. I really don't like to hear people say I can't afford it when you know darn well they really can't afford NOT to. Regardless of what you spend, if you get what you need you will be happy.
   / Is an FEL and Backhoe Worth It? #9
For me my FEL is a must, a BH would be nice but I would not have enough work around our place to justify the cost. Your needs may be different.
   / Is an FEL and Backhoe Worth It? #10
My first tractor was a 21hp 2 whl drive JD 750 which I used for several years. Actually, it worked pretty well for my needs starting out. Eventually, I traded up to a 4 whl drive JD 750 and after it using just a short while I swore I would never go back to 2 whl drive.
Using the 4x4 makes you realize how much more capable it can be in the right conditions & situations.
Some years later I moved up to a JD 790 with 4x4 and front end loader so yep, after using this one for almost 2 years I swear I will never have one without the front end loader!! There are just SO MANY USES the FEL is capable of, that going without one would make me feel naked now! ;)
Haven't really toyed with the idea of getting a BH yet, but I guess that is the last "frontier" for me to venture into. I guess maybe if I did, I might never go without one afterwards!! This tractor stuff is like an addiction!! :D
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
Hayrack (A50515)
Hayrack (A50515)
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
