FEL saved the day STUCK IN THE SAND
   / FEL saved the day STUCK IN THE SAND #1
sksmsllc
Mississippi
2004 New Holland TC48DA 4x4
Got Toatally stuck in the sand attempting to boxblade a sandy spot on a hill on the farm. Right Rear Wheel spinning Left Front Wheel spinning other two tires not moving -- I was stuck good. Could not move forward or backward. Used the Front End Loader to crawl the tractor out of the hole it was awesome! Love TC 48 DA Loader saves my first day on the tractor!
   / FEL saved the day STUCK IN THE SAND #2
Got Toatally stuck in the sand attempting to boxblade a sandy spot on a hill on the farm. Right Rear Wheel spinning Left Front Wheel spinning other two tires not moving -- !
Did you try the rear diff lock ?
   / FEL saved the day STUCK IN THE SAND #3
I've saved myself many times with that trick. I have the record of not getting stuck this past winter in the snow when all of my neighbors were not so lucky. I find it is a lot easier to push myself backwards than pull myself forwards with the bucket.
Peter
   / FEL saved the day STUCK IN THE SAND #5
Do not know what that is? where is it located?
Diferential lock, has a foot pedal on my 1700 4x4. It locks both rear wheels togather so they both turn at the same time to get you unstuck. I don't know where your engagement lever is though. It probabaly would have got you out a lot quicker and easier. Learning by your mistakes is not as easy as reading the operating manual though.
   / FEL saved the day STUCK IN THE SAND #6
right before i hit a spot that looks soft, i stomp the diff. lock.......makes a big difference...
just guessing here, and assuming the tractor has it......it's probably underneath your right foot somewhere.......don't feel badly, i didn't think mine had it when i bought it......my buddy said, "it has to have one, min tc does..."
   / FEL saved the day STUCK IN THE SAND #7
On mine(TC35D) it is behind my left foot - just a black "L" shaped rod.
   / FEL saved the day STUCK IN THE SAND #8
Glad you didn't get belly hung..whew.
We like pics. ;)
   / FEL saved the day STUCK IN THE SAND #9
On the TC48DA, the differential lock is on the right side of the transmission, probably toward the rear of the operator platform. An illustration is attached (item #35). On HST tractors, the diff. lock is on the left because you have to use the HST pedals on the right. On gear transmissions, the diff. lock is on the right so you can use it and the clutch on the left at the same time.
Okay, I saw that pedal. It's a little orange foot pedel right hand side just below the seat. I'll use that first before the FEL next time. :thumbsup: I love this tractor! Food Plots to plant next!
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
2015 Jeep Wrangler Unlimited Sport 4x4 SUV (A51694)
2015 Jeep Wrangler...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
