Hydraulic hose question on LA724 loader
   / Hydraulic hose question on LA724 loader #1
allthingsoutdoors
Kubota L3240
I just finish installing the Kubota 3rd function remove valve kit on my L3240 tractor. What a job. I have almost a full day in it.
I am about to order a thumb style add a grapple to the loader bucket.
(The Thumb) I will be mainly loading brush in the burn pile.
Should I use the smaller more flexible hoses with the 1/2" fittings or the heavier hoses with the 3/4" fittings? I am sure either would handle the flow as the cylinder is only 2" diameter with a 6" stroke. Are the heavier hoses more durable or is flexibility more important?
Thanks, Mike
   / Hydraulic hose question on LA724 loader #2
You want to use 1/4" hoses for the grapple. They are cheaper, more flexible and easier to route. Another advantage is they will help slow down the small cylinder for better control.
   / Hydraulic hose question on LA724 loader #3
Should I use the smaller more flexible hoses....
I agree with KENNY, use 1/4" hoses. Operating a grapple is very short
duration, intermittant use, so the low flow rate of a small hose is a
benefit, not a problem.
Note that if you buy some standard length hose with ends already crimped,
you can save 75% or more in cost. You can also install protection over
the hose in vulnerable areas....I have had very good luck with using plastic
flex conduit (Liquidtite) for 1/4" hoses, purchased from Home Depot..
Countyline Single Row Plow (A50123)
Countyline Single...
KUBOTA M4900 UTILITY SPECIAL TRACTOR (A51247)
KUBOTA M4900...
2016 Chevrolet Silverado 3500HD Knapheide Service Truck (A51692)
2016 Chevrolet...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
John Deere HPX815E (A50123)
John Deere HPX815E...
