TripleR
Super Star Member
- Joined
- Mar 5, 2009
- Messages
- 18,084
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
A couple of points:
First, a hydro tractor WILL speed up (or slide) on a steep enough hill, especially in high range, as I can witness today in my own back yard - I did a little of both. Think you'll be able to change the range in that situation? Think again.
Second, a gear tractor with a foot throttle is almost as easy to modulate, speed-wise, as a hydro, the constraint being primarily the upper end of the selected gear's speed range.
Well, I can't imagine being in High Range on a steep hill, but one of the first things I did when I got my L5030HSTC was try the stopping power of the HST on the steepest inclines on my property and it stopped in Mid and Low Range without any problems. If there is any lag, just rock it into reverse and you will get 4 wheel "braking". As to "sliding", that is going to be a traction issue, not HST/geared.
I have geared tractors with foot/hand throttles and while modulating speed via throttle works OK while traveling, it will screw things up when running a cutter or other implement off the PTO.
I own and operate "traditional" geared and HST and prefer HST. I will have to defer to Builder on the newer types of geared units; never used one. I did recently speak with one of our renters who runs tractors from 47 to 325 HP and he really likes HST, but can't get it on the bigger machines; guess it depends on the individual.
