I picked up an old log splitter - need to add a valve and planned to run it off tractor hydraulics. It shows signs of leaks around the rod end. I used an air compressor to cycle the cylinder and didn't see/hear any leaks (but the pressure was only up to about 100 PSI tops) but heard some gurgling and leaking around the piston. What is involved in repair? It looks like the rod cylinder end comes out but I haven't cleaned off the grime to see exactly how. The cylinder was said to come off Catapillar equipment of some kind. What do I need to get the proper seals? Rod is 2" with a bit of minor surface rust that I figure I can clean up with emery cloth. OD of cylinder is about 5.3" and a bit bigger on the rod end. I can post some pics later.
