Troybilt tow hitch for pto horse tiller
   / Troybilt tow hitch for pto horse tiller #1
flyingbfs
Does anyone out there in tractor land have a tow hitch for a pto horse tiller that you would like to sell. If so my email is flyingbfs@hotmail.com thanks Ben.
   / Troybilt tow hitch for pto horse tiller #2
Hi! I make one. Very easy . Can be hard to find. Good luck Oldmech
   / Troybilt tow hitch for pto horse tiller #3
Saw a couple sell on ebay for around $30. I would make one if it were me. I have two tractors and don't need a hitch for the TB horse.
   / Troybilt tow hitch for pto horse tiller #6
If you have any steel working equipment you can make them. I made 3 or 4 last year, tried to sell them on Ebay, and didnt have much interest. Couldn't hardly give them away. Sure wasn't worth my time. I won't go there again. What prompted me was the high prices Troy Bilt wanted for the stuff. Here is a picture of mine, perhaps you can fabricate one.
   / Troybilt tow hitch for pto horse tiller #7
Looks good. If I had a PTO model, I'd buy one off of you!
Make me a dozer blade and I'll buy it! :)
   / Troybilt tow hitch for pto horse tiller #8
Appreciate the kind words. I like making my own things when I can. Just need the ideas. I am currently meditating and thinking out an alteration to my current tandem disk to make it an offset gang modification. Saw something similar that sold for about 4 to 5 times the price of a regular tandem disk. My suspicion is that it should help alleviate the center ridge my current disk leaves. Maybe, but I will be fabricating it to where it can be semi-easy to return to original if it does not work as planned. Here is another shot of the tiller hitch and a cultivator I made up.
Good luck on the blade.....
   / Troybilt tow hitch for pto horse tiller #9
That is the cleanest Troy Bilt tiller I have ever seen other than a brand new one. Do you actually use it or did you clean it up for the photos? What year did you get it?
   / Troybilt tow hitch for pto horse tiller #10
Thanks, I take pride in taking care of my stuff. It only has about 35 hours or so run time since new, and I keep it inside, always. I do wash it after use, if it gets real dirty, but didn't for the photos you see. Yes it really is a cream puff tiller. I am the second owner, I bought it on Ebay about 5 years ago. I had to drive up near Oklahoma City to get it, and have always felt it was well worth the drive. Normally I am afraid of buying equipment unseen on Ebay, but I could tell the fellow I bought it from was nearly as meticulous as me. He kept it inside as well, and he also had a tractor with 3PH tiller, so he didn't use it much either.
You make a good point, about lack of use. Since I bought a tiller for my tractor and 3 Point Hitch, I probably only use it a couple of hours a year for smaller areas. But when I do use it, I really enjoy it. After storing away for several months, it starts on first pull. To be honest, I probably don't need it , but ................
But having said that , I would like to inject a care tip if I can. Mine has a fuel shut off valve from the tank, and when I am through for the day, I close the fuel valve and run it until it dies, to suck out all the gas from the carb. Or other tiller owners without a shut off valve can drain the carb some way before storage. Old gasoline that is left in a carb to evaporate and turn to sticky varnish is a disaster waiting to happen. Once the carb gets gummed up and stopped with varnishy gas, its very difficult to undue. I do this procedure on all my small engines, like chain saws, weed eaters, lawn mowers, generators, etc. Perhaps this advice can help a fellow tiller owner.
2013 Dodge Avenger Sedan (A50324)
2013 Dodge Avenger...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2010 Toyota Camry Sedan (A50324)
2010 Toyota Camry...
