Do you think I can do this? CatII to cat I?
   / Do you think I can do this? CatII to cat I? #1
easygo
Maine
Kubota B7800
I'm looking for advice on a conversion dilemma. I found a set of lower link arms and stabilizers for sale locally that are for a much larger tractor then mine. I have Cat I 3ph and these arms are for a Cat II.
What I hope to gain is the telescoping lower links and the rigid stabilizers instead of my turnbuckles. The whole set would cost me $200 plus my time to convert it as opposed to about $180 for the rigid stabilizers alone from a web site.
My tractor is a Kubota B7800 and the ones I may try to install are from a 45-60HP machine.
I might have to shorten the lift arm and figure out how the stabilizers would attach to my tractor. Plus I would have to buy bushings for the attachment pins. Is there any other problem I'm not thinking of???
Please share your thoughts. I'm very tempted to purchase this stuff.
   / Do you think I can do this? CatII to cat I? #2
I think the CAT II are longer making the distance to the PTO shaft longer.
Other thing is the 3pt acts as a pivot taking weight off the front wheels dpending on what you have mounted back there might get interesting :)
The Cat II is about 4" longer and it can be cut and re-welded to make it the same length as the Cat I. Many of the lower link arms are welded originally so It would not be a big deal.
Anything else I'm not considering?
   / Do you think I can do this? CatII to cat I? #4
I would take a close look at where the lower arms attach to the tractor. Cat II arms being larger may have some clearance issues.
MarkV
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
71064 (A49346)
71064 (A49346)
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2018 FABRIQUE 20FT TRAILER (A51222)
2018 FABRIQUE 20FT...
