LAND PLANE or How flat do you want it?
   / LAND PLANE or How flat do you want it? #1
dirt ditch
There was a post a while back discussing land planes and 3pt road graders so I had to take some pics of this one I came across today. While some road graders are small versions of a plane, around here this is a land plane. Not too many folks can level there driveways with this. :laughing:
   / LAND PLANE or How flat do you want it? #2
Not too many folks have a tractor that could pull that.....
   / LAND PLANE or How flat do you want it? #4
Might be handy to make your own runway with but is alot more cumbersome than a motorgrader. Looks like a transport nightmare but with that length it should do a good job.
   / LAND PLANE or How flat do you want it? #6
Those are what the big guys use. I don't think that they ever leave the property once they get assembled. The ones that I've seen were 60-80 feet long. :eek:
Yep, it takes a lot of hp to pull it but this bad boy will level out a field in just a few passes. Every year there are one or two of these planes at the largest spring farm consignment auction in this part of KS. That is where I found this one. Guess the farmers wives don't want these monsters parked in the yard when the field prep is done. Out here farmers have as much right to travel the highways with large farm equipment as folks in cars so these things get moved around.
   / LAND PLANE or How flat do you want it? #8
Looks like it would take a Kansas quarter section to turn it around!:D
Ken
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2014 FORD F-150 (A52472)
2014 FORD F-150...
