anyone pull a disc on their K2 series?
   / anyone pull a disc on their K2 series? #1
myyaz33
Nebraska
TYM T273
Just wanted to check with other T233,T273,T293 owners and see if any of you have pulled a disc behind their machine? If so how well did it work and what size? Also what type of soil conditions?
   / anyone pull a disc on their K2 series? #2
I think if you weight the light duty disc enough so it does any kind of a job, you will have trouble lifting it. If you could find a 5' disc that was a trailer type it might work for you.
   / anyone pull a disc on their K2 series? #3
I have a 5 foot Leinbach that I use with my T2734. I have used it in clay and in sandy soil. The little disc does a good job. Now have AG tires on my tractor but I still have to run it in 4-wheel drive to pull the disc. I do not have fluid in my rear tires yet. Also,I plan on installing duels on the rear when I can get around to it.
   / anyone pull a disc on their K2 series? #4
I too pull a 5' disc harrow with a T273. I do have to weigh it down with concrete blocks to get decent hard (clay) soil penetration, but it works reasonably well even in hardpan. I would say that Loaded tires and 4WD are really a must to get any traction when pulling through the heavy stuff.
   / anyone pull a disc on their K2 series? #5
I would like to see pics of your T273 with duals when you get them.
Thank for the reply's. My main reason for asking is this weekend I prepped 4 food plot areas at different locations using my KKII tiller. While it worked really well, it clearly takes a while. Was thinking the disc might speed things up. Also thought about scalping the vegetation then running the old "yard tool" on it. I really don't need to be going to the depths of the tiller if not necessary. Besides the tiller is tougher on fuel.
   / anyone pull a disc on their K2 series? #7
I will post some pics when I get around to putting them on. When I put the 12.4-16 R-1 tires on the rear I had to buy new wheels so I went ahead and got two sets. All I need to do now is make or buy a spacer and buy two new tires.
   / anyone pull a disc on their K2 series? #8
A small disk will do just what you need. Food plots are what I use mine for. Make a few passes, spread the seed and make one more pass.
This is the disc I have(5'4") But I paid $350 for it used.
Tractor 3 Point Light Adjustable Disc Harrow B245
I never had to add extra weight to it, but in heavy clay you might.
378632 (A51573)
378632 (A51573)
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
JOHN DEERE 7210R LOT NUMBER 254 (A53084)
JOHN DEERE 7210R...
CAT289D (A52472)
CAT289D (A52472)
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
