Gasoline in Diesel
Status
Not open for further replies.
   / Gasoline in Diesel #1
farmdog
Ok I admit stupidity, but I dumpted about 3 gallons of gasoline into my almost empty tc33d
diesel tank. What do I do next? cussing and crying are not options. Thanks.
   / Gasoline in Diesel #2
Drain it and refill with a full tank of diesel..May want to drain the lines ...You didn't try to start it, did you?
No, didnt try to start it, is it OK to start if I drain and refill?
   / Gasoline in Diesel #4
If you havent started it then draining it and refilling with a full tank of diesel will be more than adequate.
   / Gasoline in Diesel #5
Agreed. Whatever minute amout of gas that is in there after you drain it will dilute. I would probably drain the lines just to be on the safe side, but that's just me.
   / Gasoline in Diesel #6
a small amount of gas mixed with diesel won't hurt anything. Drain the tank as best you can, refill with diesel and drive away.
I bought this tc33d used and without a manual. How do I drain a diesel tank. Not sure where to make the connection.
   / Gasoline in Diesel #8
Go to this site for Messicks and scroll down the page and you will see where the fuel filter and fuel lines are....after you drain the tank if it were me I would pour another gallon of diesel fuel into the tank and let it drain through as well to flush any remaining gas out ...
New Holland TC-Series Service
Thanks to everybody for the help. Drained it and got it going. Seweet.
   / Gasoline in Diesel #10
Duplicate of thread in NH O/O. No need to double post. Closed.
Status
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53472)
Mitsubishi FG35...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A53473)
2015 Freightliner...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
