Lifting Sewer Waste Water
   / Lifting Sewer Waste Water #11
Really wish I had a photo of my neighbors "throne" which sat a couple feet up in the air. It basically was a straight line into the sewer pipe. Just a basement toilet for his shop... not for guests. Had to watch your head since the clearance was tight...
Excellent Information - thanks guys!
My shop will be about 100 ft away. I definitively will go with a "bigger is better" approach.
   / Lifting Sewer Waste Water #13
ide go with a lift due to the fact that any kind of water closet solution would not work for a utility sink and imo that is a must have
   / Lifting Sewer Waste Water #14
I would wonder what you mean by that? For a workshop with limited use a small lift station in a can will work well for this purpose. I have seen them work for many years with a whole house depending on them. The ones I am thinking about had Zoeller cast iron pumps in them.
   / Lifting Sewer Waste Water #15
You don't need a bigger pump, just more volume per cycle. If you decide on a Zoehler pump, be sure and use float switches. Their switch, that is made into the pump, will fail in just a couple years.
   / Lifting Sewer Waste Water #16
I have many lift pumps in and a few homes totally on sewage lift pumps. Some pump as far as 600ft. I have been installing them for over 30 years. The Gould cast iron pumps have held up for many many years. The larger the catch basin / pit, the longer run time , the longer the pump will last , and the better it will clear the pipe at each pump cycle. The larger the pit the less trouble with floats. My 2 cents worth.
I work for a very large plumbing distributor. We sell Goulds, Liberty, Sani-flow, Little Giant, Zoeller, Hartell to name a few. You can't go wrong with a Goulds or Zoeller unit.
Sorry for this - I meant a bigger tank, creating less on/off cycles but larger volumes to be pumped.
I think I need some design pointers as I am starting to read up on this.
I found this system for example: SaniPlus
Page 3 picture 6 shows the 'lift' and then then 1% fall in the line. I guess this is not possible for me as from the shop to the sewer is a 100 ft distance with 1 ft higher inlet than shop floor.
Are these systems not for me?
   / Lifting Sewer Waste Water #19
1 foot of head isn't going to be a problem. That is basically no head. You are basically going to be pumping flat. More reason for a longer pump cycle to be sure and wash out the solids.
   / Lifting Sewer Waste Water #20
Maybe someone with more experience than I can chime in, but I see a potential problem with insufficient use.
In a workshop situation, with only one part-time user, even the smallest lift pump may go weeks without activating. At 1.6 gallons per flush and a 50 gallon tank, you are looking at 30 flushes per tankful. I can go several months if not a year on 30 flushes in my workshop.
I would be seriously considering a "comfort bush" outside the back door and a small electric water heater for hot & cold hand washing draining into a gravel sump.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
10X12 PUMP (A52472)
10X12 PUMP (A52472)
