1948 Model L Gravely oil pump issues
   / 1948 Model L Gravely oil pump issues #1
zikibusey
Sorry Newby to this site. But I need some help on figuring out why I have no oil pressure or no oil in the filter or pumping out under the fill cap. When I get the Gravely started runs idles great great but no oil circulation? Thanks for any info. -Jack
   / 1948 Model L Gravely oil pump issues #2
Most times it is due to the pump becoming air bound. Try tilting the tractor back for a couple hours to allow oil to fill the line to the pump and the pump. Other way to prime the pump is to fill the line going to the filter from the block and pump. Worse case is the bottom of the tranny is filled with crud and covering the screen.
   / 1948 Model L Gravely oil pump issues #3
i just went thur **** trying to prime an L i rebuilt took the oil pump a part used 1000 grite sand paper polised pump cover check the gear to hoseing with stright edge used #3 avatsion permatex on cover , tryed to prime at lower oil line did not work got a small fuel line put on the nosel of my oil pump can from chain saw an primed at oil line up near oil filter. that worked got oil pressure now
   / 1948 Model L Gravely oil pump issues #4
I use petroleum jelly to prime oil pumps. I pack the pump with it when I assemble it. Do not use grease.
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
1979 Chevrolet P30 Step Van Box Truck (A52377)
1979 Chevrolet P30...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
40' CONTAINER (A51244)
