What exactly is the difference?
   / What exactly is the difference? #1
robertwhite
between a dash 1 (-1), dash 2 (-2) and a dash 3 (-3) on say a L3400?
Dealer told me it was just emissions although I surely don't believe it is strictly emissions.
** I am sure this has been discussed before, but I couldn't find it in a search.
   / What exactly is the difference? #2
On a L3400 it is strictly emmisions. And the good news if you can find a -1 or -2 they are at a lower dealer cost than current. I would buy it without hesitation.
But if you don't trust your dealer on a small detail like this you should consider going somewhere else were you are comfortable. But he did give you accurate info on a L3400.
Grand L's is a slightly bigger change in the newer dashes. Specifically on cab models as the latest dash allows for a Kubota BH to be installed. Also the headliner material is changed from plastic to cloth for a more upscale feel. The PTO engagement also goes to a push/pull switch. Again older stock means older (lower) cost and differences may not, to many consumers outweigh price advantage.UNLESS a BH is a future consideration.
Thanks.
Reason I didn't exactly believe him is that about half the questions I asked, he had no answer for and had to look up. And this place is Kubota only shop. :(
Heck, he had to ask another guy if the L3400 would pull a 5 ft bush hog without issues. (PTO HP puts it right at the 5hp per ft rule)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
2596 (A54757)
2596 (A54757)
2021 JOHN DEERE 524P WHEEL LOADER (A52705)
2021 JOHN DEERE...
UNUSED LANDHONOR LHR-BLC9021 TOOL STOOL (A54757)
UNUSED LANDHONOR...
Genie GTH-644 (A50490)
