Need to know what kind of Front axel fluid for YM336D
   / Need to know what kind of Front axel fluid for YM336D #1
mikereid
Jackson, GA
Yanmar YM1700
I have searched around the site. I need to know what fluid to put in the front axel of the 336D.
Thanks, Mike
   / Need to know what kind of Front axel fluid for YM336D #2
Not sure about your tractor but my 186D takes 90wt. gear oil in the front axel.
   / Need to know what kind of Front axel fluid for YM336D #3
According to the service manual it takes 7.4 qts of 90WT.
Steve
Wow - thats alot of lube
   / Need to know what kind of Front axel fluid for YM336D #5
Yes it is.
My tractor came to me so full it spewed all over when I took the dipstick/plug out and I drained about 3 qts out so maybe use the dipstick as the guide don't know what it holds for sure but that gets you started?
Steve
   / Need to know what kind of Front axel fluid for YM336D #6
Wow....that is a lot of lube. My 186D takes 3.2 qts. I just changed the oil a few weeks ago. When you check the level.....don't screw in the dipstick. Should be at the full mark without being screwed in. Good luck.
   / Need to know what kind of Front axel fluid for YM336D #7
You cant trust anything any more although the manual says quarts I suspect it means pounds which is a lot less more like a pint in volume all lost in translation from Japanese is my guess?
Steve
The 336 was a us sold machine. I would think the manual should be correct.
   / Need to know what kind of Front axel fluid for YM336D #9
My 336 manual states 8.5 qts for front drive gear case
   / Need to know what kind of Front axel fluid for YM336D #10
I have a 336D and have changed the oil twice. I used a 80/90 wt. oil and it took about 2 gallons.
2012 John Deere 7230R (A53472)
2012 John Deere...
2019 GMC Yukon 4x4 (MPV), VIN # 1GKS2BKC5KR183792 (A51572)
2019 GMC Yukon 4x4...
1998 Freightliner FL70 Roll-Off Truck, VIN # 1FV6HLBC6WH951295 (A51572)
1998 Freightliner...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
