5030 with backhoe, Can I adjust hydro psi?
   / 5030 with backhoe, Can I adjust hydro psi? #1
diggdug
Member
Midland, MI
L5030 HSD
I have a 5030 with a backhoe and fel. The backhoe bucket is 24" and can just barely lift when full with heavy soil. I was told that there is a way to increase the Hydro pressure to get a little more power to the hoe. Has anyone tried this? How do you do it? Thanks!
Anybody?
   / 5030 with backhoe, Can I adjust hydro psi? #3
Have you had it checked to see if it is set correctly now?
I have a 5030, but don't know anything about checking the pressure, but I remember reading where some have increased the pressure a little; might check the hydraulics section; sorry.
   / 5030 with backhoe, Can I adjust hydro psi? #4
First, is it an OEM hoe? If so, it is prob a BH90.
You need to get a guage to test the pressure....it is easy to do. You don't
want to mess around with relief valve pressure adjustments without a
guage.
The short answer is that there is a pressure relief valve on the hoe valve
block, but if it is set too low, that is also the pressure that your FEL will
see. Your FEL valve also has a RV, and that one could be set too low also.
If either is off, the lower one dominates.
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
2020 VOLVO VNL SLEEPER (A52576)
2020 VOLVO VNL...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
