RCK60-22BX manual needed (or setup instructions)
   / RCK60-22BX manual needed (or setup instructions) #1
jnjpream
Gold Member
Berthoud CO
BX22
Can somebody hook me up with an owners manual for the 60" belly mower for my BX? Looks like it is leaning towards one side and the cut seems a bit off.. I've heard they can be a pain to get setup right, and I'd imagine not having the instrustions on how to do it would make it that much more difficult.
Thanks.
Jeff
   / RCK60-22BX manual needed (or setup instructions) #2
sent you a pm.
   / RCK60-22BX manual needed (or setup instructions) #3
I have done it many times, and I will monitor the thread to see if there are any questions, but I am assuming the PM will cover most of it. I do want to mention one thing: One part of the procedure has to do with measuring the blade tip distance from the ground. This is very difficult. What I like to do is put down boards of a known thickness, and drive the tractor up onto the boards to give added clearance to the concrete so I can more easily measure the blade tip clearance to the concrete.
   / RCK60-22BX manual needed (or setup instructions) #4
Oops...forget to ask, anyone got an easier way to measure the blade clearance to the ground?
Ask and you shall receive eh EE_bota.. For $7 I might go pick one of those gauges up.
Thanks for the info radioman.
   / RCK60-22BX manual needed (or setup instructions) #7
Excellent. I get soooooo much good information on this site. That gauge will be mine soon. Thanks fellows.
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2015 MACK GRANITE DAY CAB (A50854)
2015 MACK GRANITE...
