dcyrilc
Elite Member
newdeal
Go forward and scoop with the bucket to either get a bucket-full, or at least loosen it up. Then drag the loose back with the bottom of the bucket, or drag back with the bucket at half curl.
If you can get on the other side, then scoop forward and dump.
You have the right tool to get that job done without tearing up your machine....I think.![]()
Beenthere has the right idea here. Place your bucket at about a 10-20 degree downward angle. Approach the pile going forward to loosen the dirt and drag across the pile in reverse to spread it. Again with a 10-20 degree down angle. This is the proper way as the angle will let the bucket slide over anything which would have the capability of damaging the FEL. The bucket should slide fairly smoothly across the ground. If the angle is too steep, the bucket will move in a series of small hops (could be as small as 1/16") creating a chattering noise. This creates rapid high stresses to the entire system.
One of the worst things you can do to your FEL is to grade either forward or backwards with the cutting edge of the bucket steep enough that it chatters as it slides across the ground.
With use and paying attention to your machine, you will begin to get a feel for when your angle is too steep for the conditions you are working. As a general rule... the harder the material, the shallower the angle.
