Hydraulic Remote hook up on Kubota 5030
   / Hydraulic Remote hook up on Kubota 5030 #1
diggdug
Member
Midland, MI
L5030 HSD
OK so I have a BH90 backhoe and to power it they ran a couple of Hydro lines to the rear of my tractor. Now i would like to use a tree planter that needs a remote to lower and raise the unit. Can I just get a valve that hooks into the existing lines? Or do I need to take it in and get the full installation done? I would like to do it as cheaply as possible. Thanks!
   / Hydraulic Remote hook up on Kubota 5030 #2
If there is a pressure and a return line, you should be able to plug in the BH.
   / Hydraulic Remote hook up on Kubota 5030 #3
Assuming that the BH lines are unvalved (power beyond) lines, then you should be able to plug valves into those lines and be good to go. At least I hope so, 'cause I'm planning on doing the same thing on my L4200.
JayC
   / Hydraulic Remote hook up on Kubota 5030 #4
Yes, you can do that very easily.
1991 Cummins NT-855-G5 250kW 3-Phase Diesel Generator (A55851)
1991 Cummins...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
MILLER XMT 350 WELDER (A55745)
MILLER XMT 350...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2017 Ford F-150 (A53422)
2017 Ford F-150...
