2 Line Remote for most Ford Tractors $379
   / 2 Line Remote for most Ford Tractors $379 #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
NEW AFTER MARKET REMOTE HYDRAULIC KIT FOR MANY FORD TRACTORS--WITH COMPLETE INSTALLATION INSTRUCTIONS-----FITS ALL FORD TRACTORS : 1955 THRU 1964 (USA produced with standard hydraulic pump)--ALL 500 THRU 900 SERIES-- 501 THRU 901 SERIES--2000-3000-4000 SERIES--FORD TRACTORS 1965 THRU 1981--2000 THRU 6600 SERIES (not for use with 10 series or platform deck tractors because of space limitations). $379 + $17 UPS shipping to lower 48. Ken Sweet
   / 2 Line Remote for most Ford Tractors $379 #2
got any pics.
can we assume this is the bolt on hyd top cover valve? is this a single spool DA setup? similar to the tisco units?
thanks
soundguy
got any pics.
thanks
soundguy
Bolts on where the cover plate is between your legs on the tranmission housing (4 bolts)--Kit comes with alum. manifold and longer bolts that goes there and the original cover plate goes back on top with longer bolts that come with the kit. Actual valve mounts on the right fender and the 2 lines go to the back from there.. Single spool with up pressure, down pressure and neutral in the canter. PM me with you email address before Monday and I will scan a copy of the parts and instructions and email them to you. Ken Sweet
   / 2 Line Remote for most Ford Tractors $379 #4
sounds like a power beyond plate and spool plus hoses and connectors in kit form.. neat.
thanks
soundguy
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
