Kubota PHD rebuild
   / Kubota PHD rebuild #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
Rather than dishing out for a new post hole digger, I found a decent used one that needed a little TLC. It's a BL80A, made by Auburn Consolidated Industries for Kubota.
Getting the gearbox separated from the boom took a little persuasion, the pin that holds it in was rusted solid in the sleeve that goes through the gearbox ears. If you ever have one of these apart, you'll see what I mean.
A little rust on the upper tapered roller bearing, probably from condensation after years of sitting outdoors. I replaced both tapered rollers, and the ball bearing on the input shaft. Washed the case out, checked the seals (still flexible) and gave it a coat of paint and fresh gear lube. Looks good and works like a charm.
Chilly
   / Kubota PHD rebuild #2
Thanks for sharing pics.When not on my tractors Id rather be bowhunting too,or vise/versa.:DBoone
I think it's the difference between want to do, and have to do.
Chilly
1992 Peterbilt 377 Sleeper Cab (A52128)
1992 Peterbilt 377...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
