2615 Hydraulic filter/fluid
   / 2615 Hydraulic filter/fluid #1
dtsdryseats
South Lyon Mi
Mahindra 2615
:confused: I have a 2615 (gear) tractor. I recently replaced the hydraulic fluid and filter for the first time. I used a wix 51663 filter and traveler universal hyd fluid from TSC
Traveller Universal Tractor Trans/Hydraulic Fluid, 5 gal. - 0806391 | Tractor Supply Company
It may be in my head but it almost seems like I am getting a hyd pump cavitation at higher RPM's now? The Wix filter is about 1/3 again shorter than the stock filter and I am not 100% convinced that the fluid is correct, though the dealer I bought it from recommended any 32 hydraulic fluid?
Can anyone enlighten me on my situation?
Thanks!
   / 2615 Hydraulic filter/fluid #2
Thanks!
You probably are cavitating the pump, and that is real hard on pump life. I'd use the factory filter. I'm not familiar with the specs on the TSC hy-trans, we recommend the factory branded Mahindra Hy-Trans, or Chevron THF-1000 or Mobil 424.
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
