MF GC 2300 broken muffler flange
   / MF GC 2300 broken muffler flange #1
massey driver
Gold Member
north of winnipeg canada
massey 175,1655 BX 2370-1
Was using the tractor the other day and could hear a strange sound comming from under the hood.I put my [gloved hand ] on the muffler and the noise would stop.I first figured it was the tin around the muffler that was ratteling.I took a hammer and tapped[put a small dent into the tin] and the noise stopped.I used it like that for a couple hrs with no more noise.The next day I used it again and no noise for awhile then it started again off and on.Finally it continued to make noise and get louder.I finally started taking a good look to see and couldn't really see anything.I used a screw driver and put it against the bolts and the muffler flange and noticed the pipe moved around a bit.Took the muffler off and sure enough the flange was broken away from the pipe.I ended up welding the flange back on and it's been good to go since then.Thats the nice thing about a AC/DC reverse polarity welder.Anyone else have the flange break off there muffler like that.Larry
   / MF GC 2300 broken muffler flange #2
Fortunately, not yet, Larry-- how many hours on it? Wondering if that's something we other 2300-series owners have to look forward to....
Any pics?
Any pics?
It was a busy day using the tractor so just took it apart,fixed it and went right back to work with it so didn't take any pics. The tractor has 1443 hrs on it as of today:thumbsup:[I know because checked to see when the oil change is due] guess that'll be comming up soon.Larry
   / MF GC 2300 broken muffler flange #4
The muffler mounting bracket cracked at about 600 hours. Made the strangest squeeking noise. I took it off and welded it. It hasn't given any trouble since. [ about 900 hours now ].
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
INBOARD DRIVE (A58374)
2013 Peterbilt 367 T/A A-Frame Gin Pole Truck (A55973)
2013 Peterbilt 367...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
