Old one dead..Shopping for NEW
   / Old one dead..Shopping for NEW #1
DennisArrow
Sugar Valley, Ga
Iseki TL 2300, Kubota RTV, Kubota B7610
My 12 YO Ryobi has finally bitten the dust I guess. The fuel bulb must be shot and the crank gear when I pull the starter is skipping engagement half the time. Last year rebuilt the rubber bits and fuel hoses in the carb and I can't even get it to fire this spring. Yes, I always put it away dry with the gas burnt out of it. Anyway, wondering what is the best/cheapest going now? I use it maybe 10 hours per year.
Requirments are:
18" would be nice
Straight or curved? Whats the difference
2 cycle is NO problem. Is 4 cycle better?
Needs to last a few years
UNDER $200 would be nice
A string bumper feed that really works
Others?????..........thanks GUYS.............Dennis
Golly.......nobody has recommendations and advice for a string trimmer replacement????
   / Old one dead..Shopping for NEW #3
Not for under $200. I've got a 20 year old Stihl, FS36, that still runs like new, but, I think I paid more than $200 when I bought it, 20 years ago ;)
   / Old one dead..Shopping for NEW #4
A good trimmer is going to cost more than 200. Husky cost me in the $300.00 range.My maruyama cost around $280.00 . I bought these several yrs ago. Prices have probably gone up
   / Old one dead..Shopping for NEW #5
The curved shaft is more difficult to control than a straight shaft, IMHO. Sometimes the curved shaft has a flexible thing in it that isn't as strong as the straight gizmo they put in a straight shaft and that can make a difference if you use it as a brush cutter.
Can't help with brand specifics. Last good one that I had was a Stihl FS80 that's now worn out, and it was more than $200 back in the day.
Just my personal opinion, but getting 12 years from a Ryobi is doing very well.
   / Old one dead..Shopping for NEW #6
Yep, the curved shaft trimmers have that flex cable . Some of the st. shaft trimmers also use a flex cable. Which IMO uses up HP. Both of my trimmers uses the solid steel shaft. Everyone probably has an opinion on this. But, I wouldn't want 1 with flex cable
   / Old one dead..Shopping for NEW #7
I've got a Poulan (Y25 I think) straight shaft trimmer that is over 10 years old...the thing has never failed to start...last summer I had to replace the string shroud...and later I had to replace the cable and liner...other than that I have never had a problem with it....
easy to get parts and easy to fix....I think I paid like $80 at Wal-Mart that long ago...
It's funny, every time I go into the place where I buy hydraulic fittings/hoses (rental/small engine repair shop)...they sell Husky and Sthil trimmers and it never fails when I'm in there someone will bring in one or the other (sthil or Husky) because it won't start...
I'm happy with the Poulan....I've also had a Ryobi even longer and other than new fuel lines and a primer bulb...it has never needed any repair shop time...
   / Old one dead..Shopping for NEW #8
Don't get a 4-cycle. That they can be used in any position is pure nonsense no matter what they say. I thought it was so cool until the tree pruner attachment fused the piston to the cylinder from a lack of oiling. In about ten minutes, only three of which were in a true "up" position.
I've been using my Troy-Bilt two cycle ever since (4+ years) and I use it with the multiple attachments at least two hours a week. I think it was $129.
You need to hold the straight and curved shaft to decide which YOU prefer. Its basically an issue of ergonomics. Except for maybe that its easier to get over and behind something with the curved one.
   / Old one dead..Shopping for NEW #9
Pretty happy with our Stihl FS-45. About $150 today. Replaced the bump head with a Weed Warrior head, because the bump head was hard to replace line.
Picked up a Stihl fs55 on Saturday...........Right on my budget of $200....Seems to be just what I needed so far as I used it on a couple hundred yards of fence line yesterday. Typical hard to start weed eater or 2 cycle problems but works just fine. Whatever string they use is really good though.......only had to bump it a few times in the work I did even though I "trimmed" a bunch of T posts and rocks........The old one with heavy duty line would have gone through a couple of feet rather than just a few inches...........
Thanks for the thoughts guys...........Dennis
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A54757)
UNUSED RAYTREE...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
PREVIEW DATES AND TIMES (A54865)
PREVIEW DATES AND...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
