BX42 coming - cut pto shaft?
   / BX42 coming - cut pto shaft? #1
ctgoldwing
Central Connecticut
L3800HST
My BX42 is going to be delivered tomorrow. Havng nothing else to think about I was wondering if anyone else is using this with an L3400 and did you have to cut the shaft to shorten it at all?
   / BX42 coming - cut pto shaft? #2
On my B7800 I had to cut both ends of the shaft (equaly) so as to fit the distance between out put and input.
I don't know the size difference between the 7800 and L3400 but I'd think they weren't too far apart.
   / BX42 coming - cut pto shaft? #3
I would wait until you have both units there and then, measure twice and cut once. If you cut at all? Ken Sweet
   / BX42 coming - cut pto shaft? #4
   / BX42 coming - cut pto shaft? #5
Also, if you plan to add a quick hitch e.g. Pat's, the PTO shaft will need to be longer than without the hitch, so I suggest getting the quick hitch installed first before cutting shaft.
Thanks - all good advise!
It was just delivered to my workplace, now I just have to have one of our trucks bring it home.
I was (optimistically) hoping that someone who had the L3400 would chime in and say how perfect the fit was without cutting :) I would be content not having to cut.
Ground Works Fertilizer Spreader (A51573)
Ground Works...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
